Introduction
Has your ear speaker stopped working? Follow this guide to install a new one.
Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
Use a spudger to disconnect the black ribbon cable labeled "2."
Use a spudger to flip up the black plastic tab holding the remaining ribbon cable in place. The black will rotate up 90 degrees, releasing the ribbon cable.
Slide the ribbon cable out of its connector, and remove the display assembly from the iPhone.
Remove the single Phillips #00 screw from the corner of the display assembly.
Use the flat end of a spudger to pry up the right side of the ear speaker cover assembly.
Turn the spudger around and use the pointed side to detach the two clips securing the top of the assembly.
Once the clips are detached, lift the cover assembly up from the device.
Slide the pointed end of the spudger into the slot under the upper right corner of the ear speaker and gently pry upwards.
Lift the ear speaker up and out of the device.
