iPhone 3G 4 Connector Disconnected
    1. iPhone 3G 4 Connector Disconnected, Broken Glass: step 1, image 1 of 1
      • If the Glass is cracked, contain further breakage by putting packaging tape on the broken glass. I recommend pitting on safety glasses in case any breakage is loose from the tape.
      Ask FixBot
    2. iPhone 3G 4 Connector Disconnected, Remove Screws: step 2, image 1 of 2 iPhone 3G 4 Connector Disconnected, Remove Screws: step 2, image 2 of 2
      • Remove the 2 screws on the Dock Connector side. Refer to the second image for taking of the front assembly.
      Ask FixBot
    3. iPhone 3G 4 Connector Disconnected, Disconnect Cable 1: step 3, image 1 of 1
      • Angle the screes to a 45 degree angle and use a spudger (or your finger) to disconnect cable 1.
      Ask FixBot
    4. iPhone 3G 4 Connector Disconnected, Disconnect Cable 2: step 4, image 1 of 1
      • Tilt the display to an almost vertical angle and use a spudger (or your finger) to disconnect cable 2.
      Ask FixBot
    5. iPhone 3G 4 Connector Disconnected, Disconnect Cable 3: step 5, image 1 of 1
      • Disconnect Cable 3. You will need to open the locking mechanism with a spudger (or your finger) to remove cable 3, otherwise it would be physically impossible to remove and reconnect cable 3.
      • Sometimes the colours are inverted. In this case, the locking mechanism latch is always the smaller colour.
      • In some Non-American countries, the latch is non-existent. In this case you would have to slide the cable off the port, and you would have to apply pressure to reconnect it.
      Ask FixBot
    6. iPhone 3G 4 Connector Disconnected, Reconnect Cable 4: step 6, image 1 of 1
      • Reconnect Cable 4 from the picture.
      Ask FixBot
To reassemble your device, follow Steps 1-5 in reverse order.
Khaled Abdo
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 56
All Time: 194
