iPhone 1st Generation Case Replacement
  1. iPhone 1st Generation Case Replacement, SIM Card: step 1, image 1 of 1
    • Insert a SIM card eject tool or paper clip into the hole next to the headphone jack.
    • Press down on the paper clip until the SIM card tray pops out.
  2. iPhone 1st Generation Case Replacement: step 2, image 1 of 1
    • Grasp the SIM card tray and slide it out of the iPhone.
  3. iPhone 1st Generation Case Replacement, Antenna Cover: step 3, image 1 of 1
    • This image shows the two tabs and two catches located on the underside of the antenna cover. The two tabs at the top of the image must be pushed towards the black cover to release them.
  4. iPhone 1st Generation Case Replacement: step 4, image 1 of 1
    • Be sure to slide the metal spudger between the dock connector and the antenna cover, and not into the dock connector itself.
    • Insert a metal spudger into the slot between the dock connector and the antenna cover. Gently pry up near the two tabs to create a small gap between the antenna cover and the silver front bezel.
  5. iPhone 1st Generation Case Replacement: step 5, image 1 of 1
    • Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
    • Repeat the same procedure on the other side of the dock connector.
  6. iPhone 1st Generation Case Replacement: step 6, image 1 of 1
    • Grasp the antenna cover on either side and slide it up and away from the iPhone. This requires some force. If it does not come free, ensure that the antenna cover is lifted up enough to free the catches.
  7. iPhone 1st Generation Case Replacement, Case: step 7, image 1 of 1
    • Remove the three Phillips #00 screws securing the rear panel to the iPhone.
  8. iPhone 1st Generation Case Replacement: step 8, image 1 of 1
    • Getting the iPhone open is a challenging feat, so don't get discouraged. Take a deep breath and make sure you have plenty of time to get the job done.
    • The small square hole is the location to insert the dental pick in the next step.
  9. iPhone 1st Generation Case Replacement: step 9, image 1 of 1
    • Start removing the rear panel on the side with the buttons.
    • Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
  10. iPhone 1st Generation Case Replacement: step 10, image 1 of 1
    • Pry up the rear panel by pulling the dental pick counterclockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
  11. iPhone 1st Generation Case Replacement: step 11, image 1 of 1
    • Use a spudger to free the rear panel from the iPhone along the corner and top.
  12. iPhone 1st Generation Case Replacement: step 12, image 1 of 1
    • Repeat the same procedure on the other side of the iPhone. Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
  13. iPhone 1st Generation Case Replacement: step 13, image 1 of 1
    • Pry up the rear panel by pulling the dental pick clockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
    • The rear panel is still attached to the iPhone by the headphone jack cable, so don't entirely remove the rear panel from the iPhone just yet.
  14. iPhone 1st Generation Case Replacement: step 14, image 1 of 1
    • Make sure the phone is off before disconnecting the headphone jack cable.
    • Use a spudger to disconnect the headphone jack cable from the logic board.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 83
All Time: 98,159
