Shop the Holiday Gift Guide
iPhone 18 Pro Max Screen Installation
View statistics:
Past 24 Hours:
3
Past 7 Days:
5
Past 30 Days:
18
All Time:
38
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. iPhone 18 Pro Max Screen Installation, Clean the frame: step 1, image 1 of 3 iPhone 18 Pro Max Screen Installation, Clean the frame: step 1, image 2 of 3 iPhone 18 Pro Max Screen Installation, Clean the frame: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Work around the fragile grounding clips as you clean the frame. If you bend one out of place, gently bend it back with your fingers or tweezers.
      • Use tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
      • Use a spudger to scrape the adhesive residue off the frame.
      • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
      Ask FixBot
    2. iPhone 18 Pro Max Screen Installation: step 2, image 1 of 1
      • Apply a few drops of high concentration (>90%) isopropyl alcohol to the adhesive residue.
      • Use a microfiber or lint-free cloth to wipe in one direction along the perimeter of the frame to clean the residue.
      • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
      Ask FixBot
    3. iPhone 18 Pro Max Screen Installation, Clean the screen: step 3, image 1 of 1
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • If you're reusing your screen, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
      Ask FixBot
    4. iPhone 18 Pro Max Screen Installation, Orient the replacement adhesive: step 4, image 1 of 2 iPhone 18 Pro Max Screen Installation, Orient the replacement adhesive: step 4, image 2 of 2
      • Without peeling any liners, lay the adhesive sheet over the frame to determine its proper orientation.
      • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
      Ask FixBot
    5. iPhone 18 Pro Max Screen Installation, Apply the replacement adhesive: step 5, image 1 of 1
      • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
      • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
      • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
      Ask FixBot
    6. iPhone 18 Pro Max Screen Installation: step 6, image 1 of 2 iPhone 18 Pro Max Screen Installation: step 6, image 2 of 2
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
      • When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
      Ask FixBot
    7. iPhone 18 Pro Max Screen Installation: step 7, image 1 of 3 iPhone 18 Pro Max Screen Installation: step 7, image 2 of 3 iPhone 18 Pro Max Screen Installation: step 7, image 3 of 3
      • Continue peeling away the liner from the adhesive as you gently press the adhesive into place.
      • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
      • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
      • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
      • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
      Ask FixBot
    8. iPhone 18 Pro Max Screen Installation: step 8, image 1 of 1
      • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
      • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
      Ask FixBot
    9. iPhone 18 Pro Max Screen Installation: step 9, image 1 of 3 iPhone 18 Pro Max Screen Installation: step 9, image 2 of 3 iPhone 18 Pro Max Screen Installation: step 9, image 3 of 3
      • Use the pull tab to peel off the large front liner from the adhesive. The pull tab is often in a corner of the liner.
      • At this point, you'll still have liners covering the perimeter. Don't remove these liners yet—they prevent the adhesive from accidentally sticking while you reassemble your iPhone.
      Ask FixBot
    10. iPhone 18 Pro Max Screen Installation, Connect the screen: step 10, image 1 of 1
      • Set the iPhone screen next to the frame such that the screen cables can comfortably reach the logic board.
      Ask FixBot
    11. iPhone 18 Pro Max Screen Installation: step 11, image 1 of 3 iPhone 18 Pro Max Screen Installation: step 11, image 2 of 3 iPhone 18 Pro Max Screen Installation: step 11, image 3 of 3
      • Use your finger or the flat end of a spudger to press and connect the two screen connectors onto the logic board.
      • Don't try to force the connectors into place. If you're having trouble, reposition them and try again.
      Ask FixBot
    12. iPhone 18 Pro Max Screen Installation, Connect the battery: step 12, image 1 of 2 iPhone 18 Pro Max Screen Installation, Connect the battery: step 12, image 2 of 2
      • Use your finger or the flat end of a spudger to press and connect the battery connector onto the logic board.
      Ask FixBot
    13. iPhone 18 Pro Max Screen Installation, Test your repair: step 13, image 1 of 1
      • This is a good point to test your repair before sealing up your iPhone:
      • Power on your iPhone and make sure it works as expected. Power it back down and continue reassembly.
      • If your iPhone doesn't turn on, connect it to a power source and try again.
      Ask FixBot
    14. iPhone 18 Pro Max Screen Installation, Install the battery connector cover: step 14, image 1 of 3 iPhone 18 Pro Max Screen Installation, Install the battery connector cover: step 14, image 2 of 3 iPhone 18 Pro Max Screen Installation, Install the battery connector cover: step 14, image 3 of 3
      • Tuck the top edge of the battery connector cover under the cutout lip.
      • Make sure the tab is tucked under the lip.
      • Align the cover by its screw hole and lay it in place.
      Ask FixBot
    15. iPhone 18 Pro Max Screen Installation: step 15, image 1 of 2 iPhone 18 Pro Max Screen Installation: step 15, image 2 of 2
      • Use a JIS 00 screwdriver to install the 1.2 mm‑long screw to secure the battery connector cover.
      Ask FixBot
    16. iPhone 18 Pro Max Screen Installation, Install the screen connector cover: step 16, image 1 of 3 iPhone 18 Pro Max Screen Installation, Install the screen connector cover: step 16, image 2 of 3 iPhone 18 Pro Max Screen Installation, Install the screen connector cover: step 16, image 3 of 3
      • Tuck the left edge of the screen connector cover under the cutout lip.
      Ask FixBot
    17. iPhone 18 Pro Max Screen Installation: step 17, image 1 of 2 iPhone 18 Pro Max Screen Installation: step 17, image 2 of 2
      • Use a JIS 00 screwdriver to install the 1.2 mm‑long screw to secure the screen connector cover.
      Ask FixBot
    18. iPhone 18 Pro Max Screen Installation, Remove the final adhesive liners: step 18, image 1 of 3 iPhone 18 Pro Max Screen Installation, Remove the final adhesive liners: step 18, image 2 of 3 iPhone 18 Pro Max Screen Installation, Remove the final adhesive liners: step 18, image 3 of 3
      • With one hand hold the screen steady.
      • Use your fingers or tweezers to peel away all perimeter liners, exposing the adhesive.
      • Make sure nothing touches the exposed adhesive.
      • Check the internals for any stray liners and remove them. There should be no liners remaining.
      Ask FixBot
    19. iPhone 18 Pro Max Screen Installation, Install the screen: step 19, image 1 of 3 iPhone 18 Pro Max Screen Installation, Install the screen: step 19, image 2 of 3 iPhone 18 Pro Max Screen Installation, Install the screen: step 19, image 3 of 3
      • Lower the screen onto the frame, beginning with the top edge.
      • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
      • Make sure the screen edge isn't pinching any cables.
      • Press along the edges of the iPhone until the screen sits flush against the frame.
      Ask FixBot
    20. iPhone 18 Pro Max Screen Installation: step 20, image 1 of 2 iPhone 18 Pro Max Screen Installation: step 20, image 2 of 2
      • Firmly squeeze around the entire perimeter of the iPhone.
      Ask FixBot
    21. iPhone 18 Pro Max Screen Installation, Apply heat to the perimeter: step 21, image 1 of 1
      • Use a hair dryer or heat gun to heat the screen perimeter until it's slightly too hot to touch.
      • The heat softens the adhesive and helps create a better bond.
      Ask FixBot
Finish Line
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 18
All Time: 38
