Framework Desktop RTC Battery Removal
View statistics:
Past 24 Hours:
Past 7 Days:
Past 30 Days:
4
All Time:
45
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Desktop RTC Battery Removal, Place the Mainboard: step 1, image 1 of 2 Framework Desktop RTC Battery Removal, Place the Mainboard: step 1, image 2 of 2
      • Place the Mainboard on your work surface with its heatsink resting on a soft, clean cloth.
      Ask FixBot
    2. Framework Desktop RTC Battery Removal, Loosen the RTC battery cover screws: step 2, image 1 of 2 Framework Desktop RTC Battery Removal, Loosen the RTC battery cover screws: step 2, image 2 of 2
      • Use your Framework Desktop Screwdriver to loosen the two captive T5 Torx screws securing the RTC battery cover.
      Ask FixBot
    3. Framework Desktop RTC Battery Removal, Remove the RTC battery cover: step 3, image 1 of 2 Framework Desktop RTC Battery Removal, Remove the RTC battery cover: step 3, image 2 of 2
      • Lift the RTC battery cover off the Mainboard and remove it.
      Ask FixBot
    4. Framework Desktop RTC Battery Removal, Disconnect the RTC battery: step 4, image 1 of 2 Framework Desktop RTC Battery Removal, Disconnect the RTC battery: step 4, image 2 of 2
      • Grip the RTC battery connector and pull it straight out of its socket to disconnect it.
      Ask FixBot
    5. Framework Desktop RTC Battery Removal, Remove the RTC battery: step 5, image 1 of 3 Framework Desktop RTC Battery Removal, Remove the RTC battery: step 5, image 2 of 3 Framework Desktop RTC Battery Removal, Remove the RTC battery: step 5, image 3 of 3
      • The RTC battery is lightly adhered to the Mainboard.
      • Use your fingers to peel the RTC battery off the Mainboard and remove it.
      Ask FixBot
Alex Diaz-Kokaisl
250,886 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 45
