Shop the Holiday Gift Guide
iPhone 17 Pro Screen Removal
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
25
All Time:
194
Comments: 9
9 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
This guide shows how to remove the screen from an iPhone 17 Pro Max.
Tools
    1. iPhone 17 Pro Screen Removal, Safety precautions: step 1, image 1 of 2 iPhone 17 Pro Screen Removal, Safety precautions: step 1, image 2 of 2
      • Let your iPhone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone.
      • Hold the power and either volume button and slide to power off your phone.
      Ask FixBot
    2. iPhone 17 Pro Screen Removal, Cracked glass preparation: step 2, image 1 of 3 iPhone 17 Pro Screen Removal, Cracked glass preparation: step 2, image 2 of 3 iPhone 17 Pro Screen Removal, Cracked glass preparation: step 2, image 3 of 3
      Tool used on this step:
      iFixit Safety Glasses
      $7.95
      Buy
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone is cracked, follow this step.
      • Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
      • Make sure there's a single strip of tape (not overlapping) across the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    3. iPhone 17 Pro Screen Removal, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 17 Pro Screen Removal, Remove the pentalobe screws: step 3, image 2 of 2
      • Use a P2 pentalobe screwdriver to remove the two 7.5 mm‑long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 17 Pro Screen Removal, Mark your opening picks: step 4, image 1 of 3 iPhone 17 Pro Screen Removal, Mark your opening picks: step 4, image 2 of 3 iPhone 17 Pro Screen Removal, Mark your opening picks: step 4, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • Alternatively, you can tape a coin 3 mm from the tip of the pick.
      Ask FixBot
    2. iPhone 17 Pro Screen Removal, Heat the bottom edge: step 5, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's slightly too hot to touch.
      • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
      Ask FixBot
    3. iPhone 17 Pro Screen Removal, Apply a suction handle: step 6, image 1 of 2 iPhone 17 Pro Screen Removal, Apply a suction handle: step 6, image 2 of 2
      • Apply a suction handle to the bottom edge of the screen, as close to the edge as possible.
      Ask FixBot
    4. iPhone 17 Pro Screen Removal, Screen bezel information: step 7, image 1 of 3 iPhone 17 Pro Screen Removal, Screen bezel information: step 7, image 2 of 3 iPhone 17 Pro Screen Removal, Screen bezel information: step 7, image 3 of 3
      • During the next step, make sure you're inserting your pick in the correct location:
      • There's a plastic bezel on the underside of the screen that sits on the frame. Insert your pick here, making sure it's completely under the bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll separate the two, complicating the repair.
      Ask FixBot
    5. iPhone 17 Pro Screen Removal, Insert an opening pick: step 8, image 1 of 3 iPhone 17 Pro Screen Removal, Insert an opening pick: step 8, image 2 of 3 iPhone 17 Pro Screen Removal, Insert an opening pick: step 8, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
      • This may take significant force. If you're having trouble, reheat the screen and try again.
      • Insert the tip of an opening pick in the gap you just created.
      Ask FixBot
    6. iPhone 17 Pro Screen Removal, Screen information: step 9, image 1 of 3 iPhone 17 Pro Screen Removal, Screen information: step 9, image 2 of 3 iPhone 17 Pro Screen Removal, Screen information: step 9, image 3 of 3
      • Don't insert your pick more than 3 mm under the screen to avoid damaging the following components:
      • The screen and ambient light sensor cables are located near the volume and Action buttons.
      • There are delicate spring contacts around the perimeter of the phone.
      • The underside of the screen has thin, metal clips that go into corresponding slots on the frame.
      Ask FixBot
    7. iPhone 17 Pro Screen Removal, Separate the bottom edge adhesive: step 10, image 1 of 3 iPhone 17 Pro Screen Removal, Separate the bottom edge adhesive: step 10, image 2 of 3 iPhone 17 Pro Screen Removal, Separate the bottom edge adhesive: step 10, image 3 of 3
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the pick inserted under the bottom right corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    8. iPhone 17 Pro Screen Removal, Remove the suction handle: step 11, image 1 of 1
      • Pull the small nub on the suction cup to remove it from the screen.
      Ask FixBot
    9. iPhone 17 Pro Screen Removal, Heat the right edge: step 12, image 1 of 3 iPhone 17 Pro Screen Removal, Heat the right edge: step 12, image 2 of 3 iPhone 17 Pro Screen Removal, Heat the right edge: step 12, image 3 of 3
      • Use a hair dryer or heat gun to heat the right edge of the screen until it's slightly too hot to touch.
      Ask FixBot
    10. iPhone 17 Pro Screen Removal, Separate the right edge adhesive: step 13, image 1 of 3 iPhone 17 Pro Screen Removal, Separate the right edge adhesive: step 13, image 2 of 3 iPhone 17 Pro Screen Removal, Separate the right edge adhesive: step 13, image 3 of 3
      • Insert a second opening pick under the bottom right corner of the screen.
      • Slide the pick up the right edge to separate the adhesive and release the two clips.
      • You may need to pry the screen up slightly to release the clips
      • Leave the pick inserted under the top right corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    11. iPhone 17 Pro Screen Removal, Heat the top edge: step 14, image 1 of 2 iPhone 17 Pro Screen Removal, Heat the top edge: step 14, image 2 of 2
      • Use a hair dryer or heat gun to heat the top edge of the screen until it's slightly too hot to touch.
      Ask FixBot
    12. iPhone 17 Pro Screen Removal, Separate the top edge adhesive: step 15, image 1 of 3 iPhone 17 Pro Screen Removal, Separate the top edge adhesive: step 15, image 2 of 3 iPhone 17 Pro Screen Removal, Separate the top edge adhesive: step 15, image 3 of 3
      • Insert a third opening pick under the top right corner of the screen.
      • Slide the pick along the top edge and just barely around the top left corner to separate the adhesive and release the two clips.
      • Don't slide the pick farther, or you may damage the ambient light sensor cable.
      • Leave the pick inserted under the top left corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    13. iPhone 17 Pro Screen Removal, Heat the left edge: step 16, image 1 of 3 iPhone 17 Pro Screen Removal, Heat the left edge: step 16, image 2 of 3 iPhone 17 Pro Screen Removal, Heat the left edge: step 16, image 3 of 3
      • Use a hair dryer or heat gun to heat the left edge of the screen until it's slightly too hot to touch.
      Ask FixBot
    14. iPhone 17 Pro Screen Removal, Separate the left edge adhesive: step 17, image 1 of 3 iPhone 17 Pro Screen Removal, Separate the left edge adhesive: step 17, image 2 of 3 iPhone 17 Pro Screen Removal, Separate the left edge adhesive: step 17, image 3 of 3
      • Insert a fourth opening pick under the bottom left corner of the screen.
      • Slide the pick up the right edge to separate the adhesive and release the clip, stopping just before the volume up button.
      • You may need to pry up the screen slightly to release the clip.
      • Don't slide the pick farther, or you may damage the screen cable.
      Ask FixBot
    15. iPhone 17 Pro Screen Removal, Prop up the screen: step 18, image 1 of 2 iPhone 17 Pro Screen Removal, Prop up the screen: step 18, image 2 of 2
      • At this point, the screen should be completely detached from the frame. If it feels stuck, go back around the perimeter and separate any remaining adhesive or clips.
      • Lift the screen straight up and swing it over the left edge, propping it up against a sturdy box or stack of books so the cables aren't strained.
      • Alternatively, you can lay the screen down flat over the left side.
      Ask FixBot
    16. iPhone 17 Pro Screen Removal, Remove the cover screws: step 19, image 1 of 1
      FixMat
      $36.95
      Buy
      • Use a JIS 00 screwdriver to remove the two screws securing the cable covers:
      • One 1.4 mm‑long screw for the screen and front sensor cable cover
      • One 1.3 mm‑long screw for the battery cover
      • Small iFixit Phillips bits are designed to work with JIS screws. You can try Phillips drivers from other manufacturers, but you risk stripping the screw.
      Ask FixBot
    17. iPhone 17 Pro Screen Removal, Remove the covers: step 20, image 1 of 3 iPhone 17 Pro Screen Removal, Remove the covers: step 20, image 2 of 3 iPhone 17 Pro Screen Removal, Remove the covers: step 20, image 3 of 3
      • Remove the two covers.
      Ask FixBot
    18. iPhone 17 Pro Screen Removal, Disconnect the battery: step 21, image 1 of 2 iPhone 17 Pro Screen Removal, Disconnect the battery: step 21, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    19. iPhone 17 Pro Screen Removal, Disconnect the screen: step 22, image 1 of 3 iPhone 17 Pro Screen Removal, Disconnect the screen: step 22, image 2 of 3 iPhone 17 Pro Screen Removal, Disconnect the screen: step 22, image 3 of 3
      • Use the tip of an opening pick or the point of a spudger to pry up and disconnect the screen and ambient light sensor press connectors.
      Ask FixBot
    20. iPhone 17 Pro Screen Removal, Remove the screen: step 23, image 1 of 1
      • Remove the screen.
      Ask FixBot
Finish Line
Author
with
Spencer Day
210,419 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 25
All Time: 194
