Introduction
This guide shows how to remove the battery from an iPhone 17 Pro.
Unplug all cables from your phone.
Hold the power and either volume button and slide to power off your phone.
Tool used on this step:iFixit Safety Glasses$7.95
Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
Make sure there's a single strip of tape (not overlapping) across the bottom edge, big enough for a suction cup to fit on.
Use a P2 pentalobe screwdriver to remove the two 7.5 mm‑long screws on either side of the charging port.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Use a hair dryer or heat gun to heat the bottom edge of the screen until it's slightly too hot to touch.
Apply a suction handle to the bottom edge of the screen, as close to the edge as possible.
There's a plastic bezel on the underside of the screen that sits on the frame. Insert your pick here, making sure it's completely under the bezel.
There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll separate the two, complicating the repair.
Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
Insert the tip of an opening pick in the gap you just created.
The screen and ambient light sensor cables are located near the volume and Action buttons.
There are delicate spring contacts around the perimeter of the phone.
The underside of the screen has thin, metal clips that go into corresponding slots on the frame.
Slide the opening pick along the bottom edge to separate the adhesive.
Leave the pick inserted under the bottom right corner to prevent the adhesive from re‑sealing.
Pull the small nub on the suction cup to remove it from the screen.
Use a hair dryer or heat gun to heat the right edge of the screen until it's slightly too hot to touch.
Insert a second opening pick under the bottom right corner of the screen.
Slide the pick up the right edge to separate the adhesive and release the two clips.
Leave the pick inserted under the top right corner to prevent the adhesive from re‑sealing.
Use a hair dryer or heat gun to heat the top edge of the screen until it's slightly too hot to touch.
Insert a third opening pick under the top right corner of the screen.
Slide the pick along the top edge and just barely around the top left corner to separate the adhesive and release the two clips.
Leave the pick inserted under the top left corner to prevent the adhesive from re‑sealing.
Use a hair dryer or heat gun to heat the left edge of the screen until it's slightly too hot to touch.
Insert a fourth opening pick under the bottom left corner of the screen.
Slide the pick up the right edge to separate the adhesive and release the clip, stopping just before the volume up button.
Lift the screen straight up and swing it over the left edge, propping it up against a sturdy box or stack of books so the cables aren't strained.
Tool used on this step:FixMat$36.95
Use a JIS 00 screwdriver to remove the two screws securing the cable covers:
One 1.4 mm‑long screw for the screen and front sensor cable cover
One 1.3 mm‑long screw for the battery cover
Use the point of a spudger to pry up and disconnect the battery press connector.
Use the tip of an opening pick or the point of a spudger to pry up and disconnect the screen and ambient light sensor press connectors.
Use a Torx Plus 4IP screwdriver to remove the screws securing the battery tray:
One 7.5 mm‑long screw
One 5.9 mm‑long screw
One 3.4 mm‑long screw
One 2.3 mm‑long screw
Nine 3.7 mm‑long screws
One 3.7 mm‑long screw
Use your finger to lift the top left corner of the battery tray and remove it.
