Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Use a Phillips screwdriver to remove the two 2.2 mm‑long screws securing the Taptic Engine connector cover.
Use tweezers or your fingers to remove the Taptic Engine connector cover.
Use the tip of a spudger to pry up and disconnect the Taptic Engine press connector.
Use a Phillips screwdriver to remove the 2.1 mm‑long screw securing the Taptic Engine.
Use the tip of a spudger to lift the Taptic Engine out of the frame until you can grip it with your fingers.
Remove the Taptic Engine.
