iPhone 16e Rear Camera Assembly Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 16e Rear Camera Assembly Removal, Disconnect the rear camera assembly: step 1, image 1 of 2 iPhone 16e Rear Camera Assembly Removal, Disconnect the rear camera assembly: step 1, image 2 of 2
      • Use the tip of a spudger to pry up and disconnect the rear camera assembly press connector.
      Ask FixBot
    2. iPhone 16e Rear Camera Assembly Removal, Remove the rear camera assembly screws: step 2, image 1 of 2 iPhone 16e Rear Camera Assembly Removal, Remove the rear camera assembly screws: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the three screws securing the rear camera assembly:
      • Two 2.3 mm‑long screws
      • One 2.5 mm‑long screw
      • Use a standoff screwdriver to remove the 2.4 mm‑long screw securing the camera spacer.
      Ask FixBot
    3. iPhone 16e Rear Camera Assembly Removal, Remove the camera spacer: step 3, image 1 of 2 iPhone 16e Rear Camera Assembly Removal, Remove the camera spacer: step 3, image 2 of 2
      • Use tweezers or your fingers to remove the camera spacer.
      Ask FixBot
    4. iPhone 16e Rear Camera Assembly Removal, Remove the rear camera assembly: step 4, image 1 of 3 iPhone 16e Rear Camera Assembly Removal, Remove the rear camera assembly: step 4, image 2 of 3 iPhone 16e Rear Camera Assembly Removal, Remove the rear camera assembly: step 4, image 3 of 3
      • Use the tip of a spudger to lift the rear camera assembly out of the frame until you can grip it with your fingers.
      • Remove the rear camera assembly.
      Ask FixBot
Alex Diaz-Kokaisl
250,047 Reputation
1,203 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 152
