Shop the Holiday Gift Guide
iPhone 16e Microphone Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
13
All Time:
134
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 16e Microphone Installation, Remove the old adhesive: step 1, image 1 of 3 iPhone 16e Microphone Installation, Remove the old adhesive: step 1, image 2 of 3 iPhone 16e Microphone Installation, Remove the old adhesive: step 1, image 3 of 3
      • Use tweezers or your fingers to remove the old adhesive from the bottom of the frame.
      • If there's adhesive residue on the frame, use high concentration isopropyl alcohol (greater than 90%) and a coffee filter or lint-free cloth to clean it.
      Ask FixBot
    2. iPhone 16e Microphone Installation, Remove the white liner: step 2, image 1 of 2 iPhone 16e Microphone Installation, Remove the white liner: step 2, image 2 of 2
      • If your microphone comes with adhesive installed, skip the next two steps.
      • While holding the microphone adhesive with one hand, use your fingers or a pair of tweezers to remove the white liner from the adhesive.
      Ask FixBot
    3. iPhone 16e Microphone Installation, Apply the adhesive to the microphone: step 3, image 1 of 3 iPhone 16e Microphone Installation, Apply the adhesive to the microphone: step 3, image 2 of 3 iPhone 16e Microphone Installation, Apply the adhesive to the microphone: step 3, image 3 of 3
      • Hold the microphone so the metal side is facing up.
      • Apply the adhesive to the microphone with the pull tab pointing up.
      Ask FixBot
    4. iPhone 16e Microphone Installation: step 4, image 1 of 2 iPhone 16e Microphone Installation: step 4, image 2 of 2
      • Remove the blue liner from the microphone adhesive.
      Ask FixBot
    5. iPhone 16e Microphone Installation: step 5, image 1 of 3 iPhone 16e Microphone Installation: step 5, image 2 of 3 iPhone 16e Microphone Installation: step 5, image 3 of 3
      • Insert the microphone at a downward angle so the adhesive adheres firmly to the frame around the sound channel.
      • Press the microphone firmly into place.
      Ask FixBot
    6. iPhone 16e Microphone Installation, Install the microphone screws: step 6, image 1 of 3 iPhone 16e Microphone Installation, Install the microphone screws: step 6, image 2 of 3 iPhone 16e Microphone Installation, Install the microphone screws: step 6, image 3 of 3
      • While pressing the microphone against the frame, use a standoff screwdriver to install two screws securing the microphone:
      • One 3.0 mm‑long screw
      • One 2.8 mm‑long screw
      • Use a tri-point Y000 screwdriver to install the one 1.0 mm‑long screw securing the microphone.
      Ask FixBot
    7. iPhone 16e Microphone Installation, Connect the microphone: step 7, image 1 of 1
      • Use the flat end of a spudger to connect the microphone press connector.
      Ask FixBot
    8. iPhone 16e Microphone Installation, Connect the screw cover: step 8, image 1 of 3 iPhone 16e Microphone Installation, Connect the screw cover: step 8, image 2 of 3 iPhone 16e Microphone Installation, Connect the screw cover: step 8, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Use your finger to press the screw cover back into place.
      • You should hear and feel a "click" when the clip engages.
      • If the remaining adhesive on the screw cover isn't sticky enough, replace it with a small piece of double sided tape, like Tesa Tape.
      Ask FixBot
    9. iPhone 16e Microphone Installation, Install the loudspeaker: step 9, image 1 of 2 iPhone 16e Microphone Installation, Install the loudspeaker: step 9, image 2 of 2
      • Place the loudspeaker into its cutout in the frame.
      Ask FixBot
    10. iPhone 16e Microphone Installation, Install the loudspeaker screws: step 10, image 1 of 2 iPhone 16e Microphone Installation, Install the loudspeaker screws: step 10, image 2 of 2
      • Use a Phillips screwdriver to install four of the screws securing the loudspeaker:
      • Two 1.4 mm‑long screws
      • Two 1.7 mm‑long screws
      • Use a tri-point Y000 screwdriver to install one 1.3 mm‑long screw.
      Ask FixBot
Author
with
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 134
