iPhone 16e Front Camera Assembly Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 16e Front Camera Assembly Removal, Remove the top connector cover screws: step 1, image 1 of 2 iPhone 16e Front Camera Assembly Removal, Remove the top connector cover screws: step 1, image 2 of 2
      • Use a tri-point Y000 screwdriver to remove the two screws securing the top connector cover:
      • One 1.0 mm‑long screw
      • One 1.3 mm‑long screw
      Ask FixBot
    2. iPhone 16e Front Camera Assembly Removal, Remove the front camera bracket: step 2, image 1 of 2 iPhone 16e Front Camera Assembly Removal, Remove the front camera bracket: step 2, image 2 of 2
      • Use tweezers or your fingers to remove the front camera bracket.
      Ask FixBot
    3. iPhone 16e Front Camera Assembly Removal, Disconnect the front camera assembly: step 3, image 1 of 3 iPhone 16e Front Camera Assembly Removal, Disconnect the front camera assembly: step 3, image 2 of 3 iPhone 16e Front Camera Assembly Removal, Disconnect the front camera assembly: step 3, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the two front camera assembly press connectors.
      Ask FixBot
    4. iPhone 16e Front Camera Assembly Removal, Remove the front camera assembly: step 4, image 1 of 3 iPhone 16e Front Camera Assembly Removal, Remove the front camera assembly: step 4, image 2 of 3 iPhone 16e Front Camera Assembly Removal, Remove the front camera assembly: step 4, image 3 of 3
      • Insert the tip of a spudger between the front camera assembly and the frame.
      • Pry up the front camera assembly until you can grip it with your fingers.
      • Remove the front camera assembly.
      Ask FixBot
Alex Diaz-Kokaisl
249,976 Reputation
1,203 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 137
