iPhone 16e Battery Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 16e Battery Removal, Peel up the battery cable adhesive: step 1, image 1 of 2 iPhone 16e Battery Removal, Peel up the battery cable adhesive: step 1, image 2 of 2
      • Slide an opening pick under the battery cable to separate the adhesive securing it to the logic board.
      • There's a pad under the battery cable that you can accidentally slide the pick under. If you do, press the pad back into place and slide the opening pick between the pad and the cable.
      Ask FixBot
    2. iPhone 16e Battery Removal, Peel up the silver tab: step 2, image 1 of 2 iPhone 16e Battery Removal, Peel up the silver tab: step 2, image 2 of 2
      • Use an opening pick or a clean fingernail to peel up the silver tab at the bottom edge of the battery.
      Ask FixBot
    3. iPhone 16e Battery Removal, Assemble the VoltClip: step 3, image 1 of 2 iPhone 16e Battery Removal, Assemble the VoltClip: step 3, image 2 of 2
      • Don't connect the VoltClip to a power source yet. The alligator clips may touch each other and cause an electrical short.
      • Plug the VoltClip's barrel connector into the USB-C elbow.
      Ask FixBot
    4. iPhone 16e Battery Removal, Attach the alligator clips: step 4, image 1 of 2 iPhone 16e Battery Removal, Attach the alligator clips: step 4, image 2 of 2
      • Attach the red alligator clip to the silver tab.
      Ask FixBot
    5. iPhone 16e Battery Removal: step 5, image 1 of 3 iPhone 16e Battery Removal: step 5, image 2 of 3 iPhone 16e Battery Removal: step 5, image 3 of 3
      • Attach the black alligator clip to the metal tab on the bottom of the loudspeaker.
      Ask FixBot
    6. iPhone 16e Battery Removal, Connect power to the VoltClip: step 6, image 1 of 2 iPhone 16e Battery Removal, Connect power to the VoltClip: step 6, image 2 of 2
      • Make sure the red alligator clip isn't touching metallic surfaces besides the silver tab.
      • Connect a powered USB-C cable to the USB-C elbow and wait 90 seconds for the adhesive to loosen.
      Ask FixBot
    7. iPhone 16e Battery Removal, Disconnect the VoltClip: step 7, image 1 of 3 iPhone 16e Battery Removal, Disconnect the VoltClip: step 7, image 2 of 3 iPhone 16e Battery Removal, Disconnect the VoltClip: step 7, image 3 of 3
      • Disconnect the USB-C cable from the elbow, then disconnect the alligator clips.
      Ask FixBot
    8. iPhone 16e Battery Removal, Remove the battery: step 8, image 1 of 3 iPhone 16e Battery Removal, Remove the battery: step 8, image 2 of 3 iPhone 16e Battery Removal, Remove the battery: step 8, image 3 of 3
      • If your battery doesn't budge during the step, reconnect the alligator clips for an additional minute and try again.
      • Grip the silver tab or use a suction handle to lift the battery out of the frame.
      • If the battery doesn't lift out easily, repeat the previous four steps.
      Ask FixBot
Alex Diaz-Kokaisl
250,018 Reputation
1,203 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 156
