Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓Reassembly steps to install the microphone in the iPhone 16 Pro.
Use tweezers to remove the old microphone adhesive from the bottom of the frame.
Tool used on this step:Cotton Swabs$4.99
Use isopropyl alcohol and a cotton swab or lint-free cloth to clean any residual microphone adhesive from the frame.
Remove the solid white adhesive liner from the new microphone adhesive.
Align the holes in the adhesive with the three holes in the microphone, and stick it into place.
Set the microphone in the frame, aligned with its screw holes.
Partially install the three screws securing the microphone:
One 3.6 mm‑long standoff screw
One 2.9 mm‑long standoff screw
One 1.3 mm‑long tri-point Y000 screw
Press the microphone against the bottom of the frame, and hold it for 15 seconds to seal the adhesive.
Fully tighten the microphone screws.
