iPhone 16 Pro Loudspeaker Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 16 Pro Loudspeaker Installation, Transfer the battery shim: step 1, image 1 of 3 iPhone 16 Pro Loudspeaker Installation, Transfer the battery shim: step 1, image 2 of 3 iPhone 16 Pro Loudspeaker Installation, Transfer the battery shim: step 1, image 3 of 3
      • If the black plastic shim beneath the battery didn't come out with the loudspeaker, skip this step.
      • Align the battery shim so it's flush with the new loudspeaker's left edge and underside. Press it onto the loudspeaker to adhere it.
      • If the shim isn't sticky, set it into the phone alongside the loudspeaker in the next step.
      Ask FixBot
    2. iPhone 16 Pro Loudspeaker Installation, Install the loudspeaker: step 2, image 1 of 3 iPhone 16 Pro Loudspeaker Installation, Install the loudspeaker: step 2, image 2 of 3 iPhone 16 Pro Loudspeaker Installation, Install the loudspeaker: step 2, image 3 of 3
      • Align the bottom edge of the loudspeaker with the frame.
      • Set the loudspeaker into its recess.
      Ask FixBot
    3. iPhone 16 Pro Loudspeaker Installation: step 3, image 1 of 2 iPhone 16 Pro Loudspeaker Installation: step 3, image 2 of 2
      • Install the four screws securing the loudspeaker:
      • Two 1.6 mm‑long Phillips screws
      • One 2.0 mm‑long Phillips screw
      • One 1.3 mm‑long tri-point Y000 screw
      Ask FixBot
Finish Line
Nick Schultz
65,500 Reputation
343 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 175
