Shop the Holiday Gift Guide
iPhone 16 Plus Microphone Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
0
All Time:
133
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Reassembly steps for the main microphone in the iPhone 16 Plus.
Tools
  • Tweezers
  • Spudger
    4.9
    1. iPhone 16 Plus Microphone Installation, Prepare the adhesive: step 1, image 1 of 1
      • Peel away the new adhesive strip from its white liner, keeping the blue liner in place.
      • Don't stick the adhesive to the microphone yet.
      Ask FixBot
    2. iPhone 16 Plus Microphone Installation, Apply the adhesive: step 2, image 1 of 3 iPhone 16 Plus Microphone Installation, Apply the adhesive: step 2, image 2 of 3 iPhone 16 Plus Microphone Installation, Apply the adhesive: step 2, image 3 of 3
      • Once the adhesive sticks to the microphone, it cannot be removed and reused. Ensure it is perfectly aligned before adhering.
      • Align the two holes in the adhesive with the three holes in the microphone, and stick it into place.
      Ask FixBot
    3. iPhone 16 Plus Microphone Installation: step 3, image 1 of 2 iPhone 16 Plus Microphone Installation: step 3, image 2 of 2
      • Use tweezers or your fingers to remove the blue plastic liner.
      Ask FixBot
    4. iPhone 16 Plus Microphone Installation, Install the microphone: step 4, image 1 of 3 iPhone 16 Plus Microphone Installation, Install the microphone: step 4, image 2 of 3 iPhone 16 Plus Microphone Installation, Install the microphone: step 4, image 3 of 3
      • Align the microphone with its screw holes and set it into the frame.
      • Press the microphone against the bottom edge of the frame once it's perfectly aligned.
      Ask FixBot
    5. iPhone 16 Plus Microphone Installation, Secure the microphone: step 5, image 1 of 2 iPhone 16 Plus Microphone Installation, Secure the microphone: step 5, image 2 of 2
      • Partially install (don't fully tighten) the four screws securing the microphone:
      • One 3.3 mm‑long standoff screw
      • One 1.3 mm‑long tri-point Y000 screw
      • One 1.5 mm‑long Phillips screw
      • One 1.3 mm‑long Phillips screw
      Ask FixBot
    6. iPhone 16 Plus Microphone Installation: step 6, image 1 of 1
      • Squeeze the microphone against the bottom of the frame for 15 seconds to compress the adhesive.
      Ask FixBot
    7. iPhone 16 Plus Microphone Installation: step 7, image 1 of 2 iPhone 16 Plus Microphone Installation: step 7, image 2 of 2
      • Fully tighten the four screws securing the microphone to the frame:
      • Two Phillips screws
      • One Tri-point Y000 screw
      • One Standoff screw
      Ask FixBot
    8. iPhone 16 Plus Microphone Installation, Connect the microphone: step 8, image 1 of 2 iPhone 16 Plus Microphone Installation, Connect the microphone: step 8, image 2 of 2
      • Use the flat end of a spudger to connect the microphone's press connector.
      Ask FixBot
Finish Line
Nick Schultz
70,853 Reputation
363 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 133
