iPhone 16 Plus Front Camera Assembly Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 16 Plus Front Camera Assembly Removal, Remove the upper connector cover: step 1, image 1 of 2 iPhone 16 Plus Front Camera Assembly Removal, Remove the upper connector cover: step 1, image 2 of 2
      • Remove the four screws securing the upper connector cover:
      • Two 1.4 mm-long Phillips screws
      • One 3.5 mm-long Phillips screw
      • One 1.0 mm-long tri-point Y000 screw
      Ask FixBot
    2. iPhone 16 Plus Front Camera Assembly Removal: step 2, image 1 of 2 iPhone 16 Plus Front Camera Assembly Removal: step 2, image 2 of 2
      • Use tweezers or your fingers to remove the upper connector cover.
      Ask FixBot
    1. iPhone 16 Plus Front Camera Assembly Removal, Disconnect the front camera and sensors: step 3, image 1 of 3 iPhone 16 Plus Front Camera Assembly Removal, Disconnect the front camera and sensors: step 3, image 2 of 3 iPhone 16 Plus Front Camera Assembly Removal, Disconnect the front camera and sensors: step 3, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the two front camera press connectors, located on the top left corner of the logic board.
      • The second press connector is underneath the first.
      Ask FixBot
    2. iPhone 16 Plus Front Camera Assembly Removal, Remove the front camera assembly: step 4, image 1 of 2 iPhone 16 Plus Front Camera Assembly Removal, Remove the front camera assembly: step 4, image 2 of 2
      • Pick up the front camera assembly and remove it from your phone.
      Ask FixBot
Nick Schultz
65,246 Reputation
343 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 163
