Shop the Holiday Gift Guide
iPhone 15 Pro Front Camera Assembly Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
21
All Time:
239
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only guide to remove the front camera assembly in an iPhone 15 Pro.
Tools
    1. iPhone 15 Pro Front Camera Assembly Removal, Move the microphone cable: step 1, image 1 of 3 iPhone 15 Pro Front Camera Assembly Removal, Move the microphone cable: step 1, image 2 of 3 iPhone 15 Pro Front Camera Assembly Removal, Move the microphone cable: step 1, image 3 of 3
      • The microphone cable covers the front sensors press connector.
      • Use the tip of an opening pick to disconnect the microphone press connector from the top left corner of the logic board.
      • Lift the cable out of the way so you can access the two press connectors on the logic board's top edge.
      Ask FixBot
    2. iPhone 15 Pro Front Camera Assembly Removal, Disconnect the front camera assembly: step 2, image 1 of 3 iPhone 15 Pro Front Camera Assembly Removal, Disconnect the front camera assembly: step 2, image 2 of 3 iPhone 15 Pro Front Camera Assembly Removal, Disconnect the front camera assembly: step 2, image 3 of 3
      • Use the tip of an opening pick to pry up and disconnect the front sensors and front camera press connectors from the top edge of the logic board.
      Ask FixBot
    3. iPhone 15 Pro Front Camera Assembly Removal, Remove the front camera assembly: step 3, image 1 of 1
      • Remove the front camera assembly.
      • Be careful not to touch or smudge the camera or sensor lenses.
      Ask FixBot
Finish Line
Spencer Day
210,422 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 239
