iPhone 15 Back Glass Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 15 Back Glass Removal, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 15 Back Glass Removal, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 15 Back Glass Removal, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Back Glass Removal, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    1. iPhone 15 Back Glass Removal, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 15 Back Glass Removal, Remove the pentalobe screws: step 3, image 2 of 2
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 15 Back Glass Removal, Heat the bottom edge: step 4, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    2. iPhone 15 Back Glass Removal, Insert an opening pick: step 5, image 1 of 3 iPhone 15 Back Glass Removal, Insert an opening pick: step 5, image 2 of 3 iPhone 15 Back Glass Removal, Insert an opening pick: step 5, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 15 Back Glass Removal, Back glass information: step 6, image 1 of 1
      • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
      • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
      Ask FixBot
    4. iPhone 15 Back Glass Removal, Separate the bottom edge adhesive: step 7, image 1 of 3 iPhone 15 Back Glass Removal, Separate the bottom edge adhesive: step 7, image 2 of 3 iPhone 15 Back Glass Removal, Separate the bottom edge adhesive: step 7, image 3 of 3
      • Don't insert your opening pick deeper than 5 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. iPhone 15 Back Glass Removal, Heat the right edge: step 8, image 1 of 1
      • Heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    6. iPhone 15 Back Glass Removal, Separate the bottom right corner adhesive: step 9, image 1 of 3 iPhone 15 Back Glass Removal, Separate the bottom right corner adhesive: step 9, image 2 of 3 iPhone 15 Back Glass Removal, Separate the bottom right corner adhesive: step 9, image 3 of 3
      • Don't insert your pick deeper than 7 mm along the right edge.
      • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
      • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone 15 Back Glass Removal, Heat the left edge: step 10, image 1 of 1
      • Heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    8. iPhone 15 Back Glass Removal, Separate the left edge adhesive: step 11, image 1 of 3 iPhone 15 Back Glass Removal, Separate the left edge adhesive: step 11, image 2 of 3 iPhone 15 Back Glass Removal, Separate the left edge adhesive: step 11, image 3 of 3
      • Along the left edge, don't insert your pick deeper than 5 mm.
      • Insert a second opening pick at the bottom edge.
      • Rotate the second pick around the bottom left corner.
      • Slide this pick up to the top left corner to separate the adhesive.
      Ask FixBot
    9. iPhone 15 Back Glass Removal, Heat the top edge: step 12, image 1 of 1
      • Heat the top edge of the back glass until it's hot to the touch.
      Ask FixBot
    10. iPhone 15 Back Glass Removal, Separate the top edge adhesive: step 13, image 1 of 3 iPhone 15 Back Glass Removal, Separate the top edge adhesive: step 13, image 2 of 3 iPhone 15 Back Glass Removal, Separate the top edge adhesive: step 13, image 3 of 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
      • You might hear and feel clicks as the top two clips release.
      • Leave this pick in place to prevent the adhesive from resealing.
      Ask FixBot
    11. iPhone 15 Back Glass Removal, Heat the top right corner: step 14, image 1 of 1
      • Heat the top right corner of the back glass until it's hot to the touch.
      Ask FixBot
    12. iPhone 15 Back Glass Removal, Separate the top right corner adhesive: step 15, image 1 of 3 iPhone 15 Back Glass Removal, Separate the top right corner adhesive: step 15, image 2 of 3 iPhone 15 Back Glass Removal, Separate the top right corner adhesive: step 15, image 3 of 3
      • Don't insert your pick deeper than 4 mm along the right edge.
      • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
      Ask FixBot
    13. iPhone 15 Back Glass Removal, Swing open the back glass: step 16, image 1 of 3 iPhone 15 Back Glass Removal, Swing open the back glass: step 16, image 2 of 3 iPhone 15 Back Glass Removal, Swing open the back glass: step 16, image 3 of 3
      • Gently swing open the back glass to the right of the phone.
      • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the back glass against a raised surface so it doesn't strain the cable.
      Ask FixBot
Clay Eickemeyer
107,861 Reputation
472 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 19
All Time: 310
