Toshiba Tecra Z50-A Hard Drive Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
88
All Time:
1,639
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Toshiba Tecra Z50-A Hard Drive is experiencing overheating, power surges, and data loss, this can be the result of an old or damaged hard drive. The hard drive is responsible for long-term data storage, which includes applications, your files, and operating systems. It usually is a 2.5-inch SATA or SSD (Solid State Drive) hard drive. This guide will walk you through the steps to replacing your hard drive. Before starting, make sure all the data is backed up and have a clear working place for keeping everything organized.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Toshiba Tecra Z50-A Hard Drive Replacement, Back Panel: step 1, image 1 of 1
      • Turn off the laptop.
      • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
      • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
      Ask FixBot
    2. Toshiba Tecra Z50-A Hard Drive Replacement: step 2, image 1 of 1
      • Lift up back panel using your hands and remove it from the rest of the laptop.
      Ask FixBot
    1. Toshiba Tecra Z50-A Hard Drive Replacement, Battery: step 3, image 1 of 1
      • Lift the plastic covering over the battery plug.
      Ask FixBot
    2. Toshiba Tecra Z50-A Hard Drive Replacement: step 4, image 1 of 1
      • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
      Ask FixBot
    3. Toshiba Tecra Z50-A Hard Drive Replacement: step 5, image 1 of 1
      • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
      Ask FixBot
    4. Toshiba Tecra Z50-A Hard Drive Replacement: step 6, image 1 of 1
      • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
      Ask FixBot
    5. Toshiba Tecra Z50-A Hard Drive Replacement: step 7, image 1 of 1
      • Lift up on the battery with your hands and remove it from the laptop.
      Ask FixBot
    1. Toshiba Tecra Z50-A Hard Drive Replacement, Hard Drive: step 8, image 1 of 1
      • Lift up on the hard drive.
      Ask FixBot
    2. Toshiba Tecra Z50-A Hard Drive Replacement: step 9, image 1 of 2 Toshiba Tecra Z50-A Hard Drive Replacement: step 9, image 2 of 2
      • Pull out the plug from the hard drive.
      Ask FixBot
2 other people completed this guide.
Dominic Hryzan
689 Reputation
3 Guides authored
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 88
All Time: 1,639
