Shop the Holiday Gift Guide
Dell XPS 15 9560 Back Panel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
4
Past 30 Days:
23
All Time:
398
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 7 - 10 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
If you need to inspect, repair, or make any replacements to the internals of your Dell XPS 15 9560, removing the back plate is an essential first step. The backplate of the Dell XPS 15 9560 sits at the bottom of the laptop, protecting the mechanical parts of the laptop such as the motherboard, SSD, HDD, fans, battery, and other components.
Some issues with the laptop may be software related and may not require you to open up the laptop. Make sure to rule out software related fixes before continuing with this guide.
Ensure that the laptop is turned off and unplugged before beginning.
Parts
Tools
    1. Dell XPS 15 9560 Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
      • Shut the laptop down.
      Ask FixBot
    2. Dell XPS 15 9560 Back Panel Replacement: step 2, image 1 of 1
      • Remove the ten 4.0 mm screws from the back panel of the laptop using a T5 Torx screwdriver.
      Ask FixBot
    3. Dell XPS 15 9560 Back Panel Replacement: step 3, image 1 of 1
      • Remove the two 5 mm screws underneath the XPS badge door using a Phillips screwdriver
      Ask FixBot
    4. Dell XPS 15 9560 Back Panel Replacement: step 4, image 1 of 1
      • Use a scribe to remove the bottom base cover from the backplate.
      Ask FixBot
Author
with
Jada Houser
884 Reputation
7 Guides authored
Clemson, Team 4-5, Hunter Fall 2021 Member of Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 23
All Time: 398
