Shop the Holiday Gift Guide
Dell XPS 15 9570 Fan Replacement
Views: 8.5K
View statistics:
Past 24 Hours:
12
Past 7 Days:
29
Past 30 Days:
136
All Time:
8,505
Comments: 6
6 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide will demonstrate the steps that need to be taken to remove the fans located in the Dell XPS 15 9570.
The fan is a piece of hardware that is responsible for cooling the computer's processor by redirecting the hot air out of the laptop. A failing fan could be recognized due to the fan running at a higher temperature than it has been previously, or the fan making more noise than was occuring when the device was new. These symptoms can result in continuous crashing due to overheating or the laptop not booting up due to permenant damage.
Before using this guide make sure the vents located on the back plate and front hinge of the device are clear of dust and debris to cancel out the possibility that the device needed better airflow.
Before beginning this repair, power off your device and unplug it from the charger. Also check that the motherboard located below the fan is kept clear of extra debris.
Parts
Tools
    1. Dell XPS 15 9570 Fan Replacement, Base Cover: step 1, image 1 of 1
      • Make sure your device is powered off and unplugged before starting
      • Flip the device over so the base cover of the computer is facing upwards.
      Ask FixBot
    2. Dell XPS 15 9570 Fan Replacement: step 2, image 1 of 3 Dell XPS 15 9570 Fan Replacement: step 2, image 2 of 3 Dell XPS 15 9570 Fan Replacement: step 2, image 3 of 3
      • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
      Ask FixBot
    3. Dell XPS 15 9570 Fan Replacement: step 3, image 1 of 2 Dell XPS 15 9570 Fan Replacement: step 3, image 2 of 2
      • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
      Ask FixBot
    4. Dell XPS 15 9570 Fan Replacement: step 4, image 1 of 1
      • Lift the back cover off of the device.
      Ask FixBot
    1. Dell XPS 15 9570 Fan Replacement, Battery: step 5, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
      Ask FixBot
    2. Dell XPS 15 9570 Fan Replacement: step 6, image 1 of 1
      • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
      Ask FixBot
    3. Dell XPS 15 9570 Fan Replacement: step 7, image 1 of 1
      • With your hands, pick up and remove the battery from the system.
      Ask FixBot
    1. Dell XPS 15 9570 Fan Replacement, Fan: step 8, image 1 of 2 Dell XPS 15 9570 Fan Replacement, Fan: step 8, image 2 of 2
      • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
      Ask FixBot
    2. Dell XPS 15 9570 Fan Replacement: step 9, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
      Ask FixBot
    3. Dell XPS 15 9570 Fan Replacement: step 10, image 1 of 2 Dell XPS 15 9570 Fan Replacement: step 10, image 2 of 2
      • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
      Ask FixBot
    4. Dell XPS 15 9570 Fan Replacement: step 11, image 1 of 1
      • Lift the right fan off of the device.
      • Repeat steps 8-11 to remove the left fan from the system board.
      • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
      Ask FixBot
2 other people completed this guide.
Author
with
Clay Caldwell
399 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 29
Past 30 Days: 136
All Time: 8,505
