Introduction
If your 1995 Toyota Corolla Controller Key has broken or missing buttons, or otherwise damaged, use this guide to replace the key board to another, brand new shell. This shell has built in key, but there are other options with removeable keys available. Specialized equipment is required to cut the new key (if needed).
Using the Phillips #0 screwdriver, remove the single screw securing the key fob shell.
While this guide shows how to switch the board between shells, unless the key has a removable blade, you will need to get the new one cut with specialized equipment.
