Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
49
All Time:
668
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
    1. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Disconnect the spark plug wire: step 1, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Disconnect the spark plug wire: step 1, image 2 of 2
      • Before you begin, ensure that the engine is powered down and cool to the touch.
      • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
      Ask FixBot
    2. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Flip the engine switch to the off position: step 2, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Flip the engine switch to the off position: step 2, image 2 of 2
      • Flip the red engine ON/OFF switch to the OFF position.
      Ask FixBot
    3. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Close the fuel valve: step 3, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Close the fuel valve: step 3, image 2 of 2
      • Flip the fuel valve lever to the OFF position.
      Ask FixBot
    4. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Turn off the ignition: step 4, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Turn off the ignition: step 4, image 2 of 2
      • Flip the ignition switch to the OFF position.
      • Ensure the wheel drive control lever is set to the neutral position.
      Ask FixBot
    5. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Allow the wheels to freewheel: step 5, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Allow the wheels to freewheel: step 5, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Allow the wheels to freewheel: step 5, image 3 of 3
      • Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
      • Repeat for the left wheel.
      Ask FixBot
    6. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Add wheel chocks: step 6, image 1 of 1
      • Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
      Ask FixBot
    1. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the fill plug: step 7, image 1 of 1
      • Use a 14 mm hex key to remove the tank fill plug.
      Ask FixBot
    2. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the fluid: step 8, image 1 of 1
      • Use a siphon to pump out as much fluid as you're able to, totaling about 14 gallons.
      Ask FixBot
    1. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the breather tube from the engine guard: step 9, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the breather tube from the engine guard: step 9, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the breather tube from the engine guard: step 9, image 3 of 3
      • Remove the end of the tank breather tube from inside the engine guard structural pipe.
      Ask FixBot
    2. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Tilt up the engine guard: step 10, image 1 of 1
      • Use a 9/16 inch socket and wrench to remove the two bolts and accompanying nuts securing the engine guard to the tank lid, one on each side.
      Ask FixBot
    3. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement: step 11, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement: step 11, image 2 of 2
      • Lift the engine guard up above the tank lid flanges.
      Ask FixBot
    4. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the tank lid bolts: step 12, image 1 of 1
      • Use a 3/8 inch socket to remove the ten bolts securing the tank lid.
      Ask FixBot
    5. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Clean the lid: step 13, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Clean the lid: step 13, image 2 of 2
      • Use a shop towel to clean and remove any remnants of silicone gasket material from the top of the lid and surrounding areas.
      • Try to prevent any silicone remnants from falling into the hydraulic fluid tank.
      Ask FixBot
    6. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the tank lid: step 14, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the tank lid: step 14, image 2 of 2
      • Lift up on the lid to break the seal around the perimeter of the gasket.
      Ask FixBot
    7. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement: step 15, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement: step 15, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement: step 15, image 3 of 3
      • Lift the tank lid out and around the engine guard mounting tabs to remove it.
      Ask FixBot
    8. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the old gasket: step 16, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the old gasket: step 16, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the old gasket: step 16, image 3 of 3
      • When peeling up the gasket, hold a shop towel underneath the lip of the tank to prevent any silicone remnants from falling in.
      • Peel the gasket up from around the perimeter of the tank.
      • Remove the gasket.
      Ask FixBot
    9. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Reinstallation tip: step 17, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Reinstallation tip: step 17, image 2 of 2
      • Before reinstallation, remove all remnants of old silicone gasket from both the rim of the fluid tank as well as the tank's lid.
      Ask FixBot
    1. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Loosen the fitting's lock nut: step 18, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Loosen the fitting's lock nut: step 18, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Loosen the fitting's lock nut: step 18, image 3 of 3
      • Use a 7/8 inch open-ended wrench or an adjustable wrench to loosen the lock nut closest to the valve on the actuator fitting.
      Ask FixBot
    2. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Rotate the actuator valve horizontal: step 19, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Rotate the actuator valve horizontal: step 19, image 2 of 2
      • Rotate the actuator valve so the return tube and relief valve are horizontal and parallel to the tank opening, facing the engine.
      Ask FixBot
    3. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the relief valve: step 20, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the relief valve: step 20, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the relief valve: step 20, image 3 of 3
      • Use a 1-1/16 inch wrench to loosen and remove the relief valve.
      • This may require a bit of force. Use a breaker bar if necessary.
      Ask FixBot
    4. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the return tube: step 21, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the return tube: step 21, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the return tube: step 21, image 3 of 3
      • Use a pipe wrench to remove the return tube.
      Ask FixBot
    5. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Loosen the actuator valve: step 22, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Loosen the actuator valve: step 22, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Loosen the actuator valve: step 22, image 3 of 3
      • Rotate the actuator valve counterclockwise to loosen it from the tank fitting.
      • Rotate the valve until the plunger assembly becomes blocked by the lip of the tank edge.
      Ask FixBot
    6. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement: step 23, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement: step 23, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement: step 23, image 3 of 3
      • Using a long flathead screwdriver, pivot one end off of the edge of the tank, compressing the plunger assembly on the actuator valve.
      • While the plunger assembly is compressed, rotate the actuator valve down, past the edge of the tank, and onto the strike plate.
      • Repeat the last two steps to continue to loosen the actuator valve from the tank fitting.
      Ask FixBot
    7. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Reassembly tip: step 24, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Reassembly tip: step 24, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Reassembly tip: step 24, image 3 of 3
      • Reassembly tip: In order to bring the plunger assembly backwards, up and over the tank edge, use an open-ended wrench to compress the plunger assembly while rotating the actuator valve.
      Ask FixBot
    8. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the actuator valve: step 25, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the actuator valve: step 25, image 2 of 2
      • Remove the actuator valve.
      Ask FixBot
    9. Barreto Tillers E1320HTRLR 2016 Actuator Valve Replacement, Remove the tank fitting: step 26, image 1 of 1
      • Use a 7/8 inch wrench to remove the tank fitting.
      • During reinstallation, install the fitting as shown, with the smaller, stationary nut facing the tank wall.
      Ask FixBot
Carsten Frauenheim
173,364 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 49
All Time: 668
