Introduction
Go to step 1 ↓Use this guide to remove or replace the two screws securing the iPhone 12 display panel. These are the only screws on the exterior of the iPhone. They use a five-point design that is unique to Apple, requiring a specialty P2 pentalobe driver for removal.
Tools
Power off your iPhone before beginning disassembly.
Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
13 other people completed this guide.
5 Guide Comments
why is this a thing
This is perfect, thank you! I wasn’t sure I’d be able to do this repair, but with this expert guidance I have succeeded. I’m ready for level 3.
well done - would you like medal
someone just pointed out the fact it says to discharge the battery -
‘Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. ‘
you are removing the 2 pentalobes, not anything ‘internal’
Hello kindle explain what you mean by discharging of battery Thanks
