Introduction
Go to step 1 ↓Prerequisite only! This guide shows how to siphon and drain out the fourteen gallons of hydraulic fluid in the Barreto E1320 Tiller for internal access and servicing.
Tools
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Flip the red engine ON/OFF switch to the OFF position.
Flip the ignition switch to the OFF position.
Ensure the wheel drive control lever is set to the neutral position.
Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
Repeat for the left wheel.
Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
Use a siphon to pump out as much fluid as you're able to, totaling about 14 gallons.
