Belkin WeMo Light Switch Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
85
All Time:
1,991
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 50 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
While a smart switch is a convenient installation that allows users to control lights from anywhere in their homes, it is still susceptible to malfunctions/errors. If your switch no longer functions, you may need to replace it. This guide will tell a user how to remove and replace their WeMo Light Switch.
Tools
    1. Belkin WeMo Light Switch Replacement, Switch: step 1, image 1 of 1
      • Open up your breaker box.
      • Breaker boxes are commonly located in garages, basements, or on a wall on the outside of the house.
      • Turn off the breaker that corresponds to the circuit your WeMo Light Switch is connected to.
      Ask FixBot
    2. Belkin WeMo Light Switch Replacement: step 2, image 1 of 2 Belkin WeMo Light Switch Replacement: step 2, image 2 of 2
      • Once you have ensured the power to the circuit is disconnected, you may continue with the disassembly.
      • Remove the faceplate of the light switch by prying it off with a flathead screwdriver. The plate should come off if lightly pried.
      Ask FixBot
    3. Belkin WeMo Light Switch Replacement: step 3, image 1 of 3 Belkin WeMo Light Switch Replacement: step 3, image 2 of 3 Belkin WeMo Light Switch Replacement: step 3, image 3 of 3
      • Using a Phillips #0 screwdriver, remove the two screws on the top and bottom of the switch.
      • Pull out the switch from the wall to reveal its connections.
      Ask FixBot
    4. Belkin WeMo Light Switch Replacement: step 4, image 1 of 2 Belkin WeMo Light Switch Replacement: step 4, image 2 of 2
      • Remove the caps from the light switch's connected wires, and detach the switch from the wall.
      • The green ground wire may be held in place by a screw. Use your flathead screwdriver to loosen the screw and remove the wire.
      Ask FixBot
    5. Belkin WeMo Light Switch Replacement: step 5, image 1 of 1
      • Once the removal process is complete, you may install a new light switch.
      Ask FixBot
Kevin Ho
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 85
All Time: 1,991
