Epson TM-U300 Cutter Blade Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
71
All Time:
829
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Does your Epson TM-U300 printer not cut paper as well as it used to? Does the cutter keep jamming/making strange noises?
This guide shows you how to replace the blade.
Please go easy on me since this is the first guide I’ve ever submitted on iFixit. Thanks!
Parts
Tools
    1. Epson TM-U300 Cutter Blade Replacement, Remove the cutter unit: step 1, image 1 of 3 Epson TM-U300 Cutter Blade Replacement, Remove the cutter unit: step 1, image 2 of 3 Epson TM-U300 Cutter Blade Replacement, Remove the cutter unit: step 1, image 3 of 3
      • Make sure the power supply/interface cables are disconnected before proceeding!
      • Open the print head/ribbon cartridge cover.
      • Remove the two Phillips screws securing the two grounding brackets which hold the cutter unit in place.
      • Set the metal brackets aside.
      • Do not pull on them forcibly – you risk tearing the grounding wires.
      • Remove the cutter, being careful not to tear/pinch the cable coming from it.
      • Disconnect the cable connecting the cutter to the printer.
      Ask FixBot
    2. Epson TM-U300 Cutter Blade Replacement, Disassemble the cutter: step 2, image 1 of 3 Epson TM-U300 Cutter Blade Replacement, Disassemble the cutter: step 2, image 2 of 3 Epson TM-U300 Cutter Blade Replacement, Disassemble the cutter: step 2, image 3 of 3
      • Caution: The screws are quite soft and easy to strip.
      • Make sure the cutter assembly is oriented so that the motor/gears face you.
      • Remove the three screws holding the two halves in place.
      • Separate the two halves, making sure not to damage the wires.
      Ask FixBot
    3. Epson TM-U300 Cutter Blade Replacement, Remove the blade: step 3, image 1 of 3 Epson TM-U300 Cutter Blade Replacement, Remove the blade: step 3, image 2 of 3 Epson TM-U300 Cutter Blade Replacement, Remove the blade: step 3, image 3 of 3
      • The blade will be accessible after separating the two halves.
      • The blade is sharp! Be careful not to injure yourself.
      • Make sure to note the position the blade is installed in.
      • The toothed edge should be facing the opening for the paper, with the longer of the three notches on the right (assuming the frame is oriented as pictured).
      • Make sure to route the wires coming from the cutter assembly through the groove in the left hinge of the print head cover when reinstalling the assembly into the printer.
      Ask FixBot
To reassemble your printer, follow these instructions in reverse order.
Fifo F
148 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 71
All Time: 829
