iPhone 11 Pro Max Battery Cell Replacement
    1. iPhone 11 Pro Max Battery Cell Replacement, Disassemble the old battery: step 1, image 1 of 3 iPhone 11 Pro Max Battery Cell Replacement, Disassemble the old battery: step 1, image 2 of 3 iPhone 11 Pro Max Battery Cell Replacement, Disassemble the old battery: step 1, image 3 of 3
      • Start out by removing the tape covering the BMS.
      Ask FixBot
    2. iPhone 11 Pro Max Battery Cell Replacement, Remove the mylar tape: step 2, image 1 of 2 iPhone 11 Pro Max Battery Cell Replacement, Remove the mylar tape: step 2, image 2 of 2
      • Open the flaps on the sides.
      Ask FixBot
    3. iPhone 11 Pro Max Battery Cell Replacement: step 3, image 1 of 3 iPhone 11 Pro Max Battery Cell Replacement: step 3, image 2 of 3 iPhone 11 Pro Max Battery Cell Replacement: step 3, image 3 of 3
      • Flip the battery over and peel the tape off.
      Ask FixBot
    4. iPhone 11 Pro Max Battery Cell Replacement, Remove the protective cover: step 4, image 1 of 2 iPhone 11 Pro Max Battery Cell Replacement, Remove the protective cover: step 4, image 2 of 2
      • Remove the plastic cover.
      Ask FixBot
    5. iPhone 11 Pro Max Battery Cell Replacement: step 5, image 1 of 3 iPhone 11 Pro Max Battery Cell Replacement: step 5, image 2 of 3 iPhone 11 Pro Max Battery Cell Replacement: step 5, image 3 of 3
      • Unwrap the BMS.
      Ask FixBot
    6. iPhone 11 Pro Max Battery Cell Replacement: step 6, image 1 of 3 iPhone 11 Pro Max Battery Cell Replacement: step 6, image 2 of 3 iPhone 11 Pro Max Battery Cell Replacement: step 6, image 3 of 3
      • Unfold the BMS.
      Ask FixBot
    7. iPhone 11 Pro Max Battery Cell Replacement: step 7, image 1 of 2 iPhone 11 Pro Max Battery Cell Replacement: step 7, image 2 of 2
      • Finish removing the tape.
      Ask FixBot
    8. iPhone 11 Pro Max Battery Cell Replacement: step 8, image 1 of 1
      • Flip the battery over; you should be able to see the anode and cathode terminal strips of the battery.
      Ask FixBot
    9. iPhone 11 Pro Max Battery Cell Replacement, Cut the BMS from the battery: step 9, image 1 of 3 iPhone 11 Pro Max Battery Cell Replacement, Cut the BMS from the battery: step 9, image 2 of 3 iPhone 11 Pro Max Battery Cell Replacement, Cut the BMS from the battery: step 9, image 3 of 3
      • Cut the terminal strips to remove the BMS.
      • Ceramic scissors are preferred here, but normal scissors can be used if you exercise caution. Under no circumstances should you try to sever both terminals with one cut; doing so will short the terminals and could potentially cause the battery to explode. Instead, cut one terminal at a time, from the side, not across the cell.
      • Please dispose of the old battery safely and in an ecologically friendly manner.
      Ask FixBot
    10. iPhone 11 Pro Max Battery Cell Replacement, Rebuild the battery: step 10, image 1 of 1
      • The new battery cell.
      Ask FixBot
    11. iPhone 11 Pro Max Battery Cell Replacement, Set the BMS in place: step 11, image 1 of 2 iPhone 11 Pro Max Battery Cell Replacement, Set the BMS in place: step 11, image 2 of 2
      • After trimming any excess terminals from the BMS contacts, place the BMS on the battery cell.
      • Fold the terminal strips over onto the contacts on the BMS.
      Ask FixBot
    12. iPhone 11 Pro Max Battery Cell Replacement, Weld the BMS to the battery cell terminals: step 12, image 1 of 3 iPhone 11 Pro Max Battery Cell Replacement, Weld the BMS to the battery cell terminals: step 12, image 2 of 3 iPhone 11 Pro Max Battery Cell Replacement, Weld the BMS to the battery cell terminals: step 12, image 3 of 3
      • Spot weld the terminals to the BMS.
      • Trim the excess terminal strips.
      • Spot welding is by far the preferred method of attaching the terminal strips. However, they can be soldered carefully as long as you minimize the amount of heat transferred from the terminal strips into the battery cell itself.
      Ask FixBot
    13. iPhone 11 Pro Max Battery Cell Replacement, Install the protective cover: step 13, image 1 of 3 iPhone 11 Pro Max Battery Cell Replacement, Install the protective cover: step 13, image 2 of 3 iPhone 11 Pro Max Battery Cell Replacement, Install the protective cover: step 13, image 3 of 3
      • Place the double-sided tape over the BMS.
      • Peel off the protective paper.
      • Stick on the plastic cover.
      Ask FixBot
    14. iPhone 11 Pro Max Battery Cell Replacement, The outer covering: step 14, image 1 of 1
      • Here's the outer covering sticker.
      Ask FixBot
    15. iPhone 11 Pro Max Battery Cell Replacement, Install the outer covering: step 15, image 1 of 3 iPhone 11 Pro Max Battery Cell Replacement, Install the outer covering: step 15, image 2 of 3 iPhone 11 Pro Max Battery Cell Replacement, Install the outer covering: step 15, image 3 of 3
      • Flip the battery over and place the sticker on the back as shown.
      • Return to the front side and fold the top over the plastic cover.
      • Fold up the sides.
      Ask FixBot
    16. iPhone 11 Pro Max Battery Cell Replacement: step 16, image 1 of 1
      • The battery has been rebuilt.
      Ask FixBot
2 other people completed this guide.
Jerry Wheeler
101,313 Reputation
92 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 46
Past 30 Days: 205
All Time: 1,044
