iPhone 11 Pro Back Glass Replacement
Video Overview
  1. iPhone 11 Pro  Back Glass Replacement, Choose The Right Laser Drawing: step 1, image 1 of 1
    • Place the iPhone 11 Pro back glass under the probe for focusing. Then place the iPhone 11 Pro back glass on the operating panel.
    • Choose ‘iPhone 11 Pro’ from the model list and click ‘Load’ to load the drawing.
  2. iPhone 11 Pro  Back Glass Replacement, Scan The Back Glass With Laser: step 2, image 1 of 1
    • Adjust the laser light scanning area on the back glass.
    • Once finished, get the parameter set and click ‘Mark’ to scan the back glass with the laser light.
  3. iPhone 11 Pro  Back Glass Replacement, Scan The Glass Around The Triple-lens Camera With Laser: step 3, image 1 of 1
    • The laser light scanning didn’t work well with the triple-lens camera area here.
    • After several attempts and experiments, REWA LAB successfully completed a specialized drawing for the triple-lens camera area.
    • Scan the triple-lens camera area again with the laser with the help of the drawing.
  4. iPhone 11 Pro  Back Glass Replacement, Separate The Back Glass From The Mid-frame: step 4, image 1 of 1
    • The scanned back glass can be separated easily. However, the glass around the triple-lens camera needs further operation.
    • Our commonly used tools failed to remove the glass here, so we used a glass cutter, a grinding tool, a Sculpture Knife and a Cutting Nipper to remove the glass around the triple-lens camera.
    • Once completed, remove residual black adhesive with the Laser Machine.
  5. iPhone 11 Pro  Back Glass Replacement, Big Hole Back Glass: step 5, image 1 of 1
    • The camera holder ring of iPhone 11 series is harder and comes with thick inside walls, adding to the difficulty of polishing. Meanwhile, the camera lens can also be easily damaged during polishing.
    • So we highly recommend replacement back glass with a big camera hole for iPhone 11 series back glass repair.
Phryne
20,416 Reputation
18 Guides authored
Past 24 Hours: 7
Past 7 Days: 60
Past 30 Days: 312
All Time: 98,417
