Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable
    1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable, Unplug: step 1, image 1 of 1
      • Before starting, remember to disconnect the outlet from the mains.
      Ask FixBot
    2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 2, image 1 of 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 2, image 2 of 2
      • Remove the dust case and the seal on the back of the device.
      Ask FixBot
    3. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 3, image 1 of 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 3, image 2 of 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 3, image 3 of 3
      • Unscrew the six screws from the pad.
      • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
      Ask FixBot
    4. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 4, image 1 of 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 4, image 2 of 2
      • Using a screwdriver or screwdriver, unscrew and open the device.
      Ask FixBot
    5. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 5, image 1 of 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 5, image 2 of 2
      • Unscrew the two screws from the domino to pull out the brown and blue cables.
      Ask FixBot
    6. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 6, image 1 of 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 6, image 2 of 2
      • Reconnect the new cable to the domino.
      • Then replace the cable, the sheath must arrive between the two pads and the sleeve must be positioned in its housing.
      Ask FixBot
    7. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 7, image 1 of 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 7, image 2 of 3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 7, image 3 of 3
      • Replace the shell, then screw it back on.
      • Remember to put the joint back in its place.
      Ask FixBot
    8. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 8, image 1 of 2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 8, image 2 of 2
      • Reposition the part, then lock the engine with a screwdriver to screw.
      • Put the tray back on and screw the screws.
      Ask FixBot
    9. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: step 9, image 1 of 1
      • Finally, reposition the vacuum bag.
      Ask FixBot
Finish Line
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
17,052 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
39 Members
1,630 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 32
All Time: 341
