Mac mini Model A1283 Audio Board Replacement
  1. Mac mini Model A1283 Audio Board Replacement, Top Housing: step 1, image 1 of 2 Mac mini Model A1283 Audio Board Replacement, Top Housing: step 1, image 2 of 2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Mac mini Model A1283 Audio Board Replacement: step 2, image 1 of 3 Mac mini Model A1283 Audio Board Replacement: step 2, image 2 of 3 Mac mini Model A1283 Audio Board Replacement: step 2, image 3 of 3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Mac mini Model A1283 Audio Board Replacement: step 3, image 1 of 2 Mac mini Model A1283 Audio Board Replacement: step 3, image 2 of 2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini Model A1283 Audio Board Replacement: step 4, image 1 of 2 Mac mini Model A1283 Audio Board Replacement: step 4, image 2 of 2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini Model A1283 Audio Board Replacement: step 5, image 1 of 2 Mac mini Model A1283 Audio Board Replacement: step 5, image 2 of 2
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini Model A1283 Audio Board Replacement: step 6, image 1 of 2 Mac mini Model A1283 Audio Board Replacement: step 6, image 2 of 2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
  7. Mac mini Model A1283 Audio Board Replacement, Audio Board: step 7, image 1 of 1
    • Remove the single Phillips screw between the headphone and microphone jacks on the audio board.
  8. Mac mini Model A1283 Audio Board Replacement: step 8, image 1 of 1
    • Use the flat end of a spudger to pry the audio ribbon cable connector off the interconnect board.
  9. Mac mini Model A1283 Audio Board Replacement: step 9, image 1 of 2 Mac mini Model A1283 Audio Board Replacement: step 9, image 2 of 2
    • Use the tip of a spudger to depress the audio board retaining clip (shown in red) to release the audio board from the bottom housing.
    • Lift the audio board from its free end and remove it from the mini.
    • Don't forget to transfer the audio ribbon cable to your new audio board.
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 64
All Time: 17,903
