iPad Wi-Fi Display Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Wi-Fi Display Assembly Replacement, Display Assembly: step 1, image 1 of 3 iPad Wi-Fi Display Assembly Replacement, Display Assembly: step 1, image 2 of 3 iPad Wi-Fi Display Assembly Replacement, Display Assembly: step 1, image 3 of 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad Wi-Fi Display Assembly Replacement: step 2, image 1 of 2 iPad Wi-Fi Display Assembly Replacement: step 2, image 2 of 2
    • Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
  3. iPad Wi-Fi Display Assembly Replacement: step 3, image 1 of 2 iPad Wi-Fi Display Assembly Replacement: step 3, image 2 of 2
    • With one spudger, work your way along the right edge of the iPad.
    • The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
    • Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
    • Be Careful: pry carefully and gently - if you feel resistance, stop and try another place. There are around 14 clips holding the screen in place. These are very fragile and will break easily. They are replaceable, but without them your iPad screen will not stay in.
  4. iPad Wi-Fi Display Assembly Replacement: step 4, image 1 of 1
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not attempt to remove the display at this time, as it is attached to the rear panel assembly.
  5. iPad Wi-Fi Display Assembly Replacement: step 5, image 1 of 1
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
  6. iPad Wi-Fi Display Assembly Replacement: step 6, image 1 of 3 iPad Wi-Fi Display Assembly Replacement: step 6, image 2 of 3 iPad Wi-Fi Display Assembly Replacement: step 6, image 3 of 3
    • Use the edge of a plastic opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
  7. iPad Wi-Fi Display Assembly Replacement: step 7, image 1 of 1
    • Use a plastic opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  8. iPad Wi-Fi Display Assembly Replacement: step 8, image 1 of 2 iPad Wi-Fi Display Assembly Replacement: step 8, image 2 of 2
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
  9. iPad Wi-Fi Display Assembly Replacement: step 9, image 1 of 1
    • Remove the display assembly from the rear panel assembly.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 19,092
