Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement
  1. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: step 1, image 3 of 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: step 2, image 1 of 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: step 2, image 2 of 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: step 2, image 3 of 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: step 3, image 1 of 2 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: step 3, image 2 of 2
    • Undo the screw on the Mini-PCI card cover labeled "C"
    • This screw will remain within the panel
    • Remove the panel from the chassis.
  4. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: step 4, image 1 of 1
    • Disconnect the antenna cables from the Mini-PCI card.
  5. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: step 5, image 1 of 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: step 5, image 2 of 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: step 5, image 3 of 3
    • Use your fingertips to carefully spread apart the white plastic tabs.
    • Flip the Mini-PCI card up at a 45 degree angle.
    • Remove the card from the computer by sliding out diagonally
    • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
charlierefvem
854 Reputation
7 Guides authored
Cal Poly, Team 13-2, Forte Winter 2011 Member of Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 4,462
