Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Spudger4.9
Use the flat end of a spudger to disconnect the lock button press connector, then the volume button press connector.
Use a JCIS or JIS 00 screwdriver to remove four screws securing the volume buttons:
Two 2.0 mm‑long screws securing the volume buttons bracket
Two 1.4 mm‑long screws securing the volume buttons ribbon cable
Use an opening pick to slice the adhesive under the lock button ribbon cable.
Lift the lock button ribbon cable out of the way.
Slide an opening pick under the volume buttons ribbon cable and between the volume button bracket and the frame.
Once the ribbon cable and bracket are loose, lift them out of the iPad.
Use a JCIS or JIS 00 screwdriver to remove the four 1.6 mm‑long screws securing the volume button caps.
Slide the tip of a pair of angled tweezers through the plunger hole to push the volume button retaining brackets and caps out of the iPad frame.
