iPad Pro 13" USB-C Charging Port Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPad Pro 13" USB-C Charging Port Installation, Clean the iPad frame: step 1, image 1 of 2 iPad Pro 13" USB-C Charging Port Installation, Clean the iPad frame: step 1, image 2 of 2
      • If the replacement USB‑C port includes new adhesive, use high-concentration (>90%) isoporopyl alcohol and a lint-free cloth to clean the adhesive residue from the iPad frame.
      • If you don't have new adhesive, skip this step. The residual adhesive will help the port stay in place and conduct heat to the frame.
      Ask FixBot
    2. iPad Pro 13" USB-C Charging Port Installation, Place the USB-C port: step 2, image 1 of 2 iPad Pro 13" USB-C Charging Port Installation, Place the USB-C port: step 2, image 2 of 2
      • If the new port has adhesive pre-applied, remove any liners. If the adhesive securing the port to the frame is not yet applied, remove one liner, apply it to the port, then remove the other liner.
      • If the new port doesn't include new adhesive, we recommend against using thin, double‑sided tape instead.
      • Place the USB-C charging port into its recess in the frame.
      Ask FixBot
    3. iPad Pro 13" USB-C Charging Port Installation, Secure the USB-C port: step 3, image 1 of 2 iPad Pro 13" USB-C Charging Port Installation, Secure the USB-C port: step 3, image 2 of 2
      • Use a JCIS or JIS 00 screwdriver to install the three screws securing the USB-C charging port:
      • Two 2.0 mm‑long screws securing the port to the frame of the iPad
      • One 1.4 mm‑long screw securing the ribbon cable to the iPad
      Ask FixBot
    4. iPad Pro 13" USB-C Charging Port Installation, Connect the USB-C port: step 4, image 1 of 3 iPad Pro 13" USB-C Charging Port Installation, Connect the USB-C port: step 4, image 2 of 3 iPad Pro 13" USB-C Charging Port Installation, Connect the USB-C port: step 4, image 3 of 3
      • Use the flat end of a spudger or your finger to connect the USB-C charging port press connector.
      • For this wide press connector, first press on one side, then the other.
      • Press the ribbon cable down for 10 seconds to make sure it's adhered to the iPad.
      Ask FixBot
Finish Line
Nick Schultz
65,742 Reputation
343 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 75
