Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Use a pair of angled tweezers to gently peel up the black grounding sticker covering the back of the camera.
Place the flat end of a spudger between the camera ribbon cable and the top button ribbon cable, against the camera press connector.
While holding the top button ribbon cable down with the spudger, twist the spudger to disconnect the rear camera press connector.
Use a spudger to break the glue dots near the top-left and bottom-right corners of the camera.
