Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Spudger4.9
Wrap a microfiber or lint-free cloth around a spudger and apply some high-concentration (>90%) isopropyl alcohol to the cloth.
Clean the camera housing, being careful not to scratch the lens.
If the adhesive isn't already on the camera, apply the new adhesive to the camera around the lens, making sure to match the notches in the adhesive with the notches in the camera.
Remove any liners.
Use the flat end of a spudger or your finger to connect the camera press connector.
Firmly press the camera into place for ten seconds to let the adhesive bond.
Use a microfiber or lint-free cloth and high-concentration (>90%) isopropyl alcohol to clean the back of the camera.
Let the camera dry completely.
Use tweezers or your fingers to place the grounding sticker over the camera. The tabs should extend past the camera's left and bottom edges.
Use a spudger or your fingers to press down the grounding sticker, including its tabs on the sides of the camera.
