Shop the Holiday Gift Guide
iPad Pro 13" Lock Button Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
11
All Time:
122
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. iPad Pro 13" Lock Button Removal, Remove the lock button screws: step 1, image 1 of 2 iPad Pro 13" Lock Button Removal, Remove the lock button screws: step 1, image 2 of 2
      • Use a JCIS or JIS 00 screwdriver to remove the two screws securing the lock button and bracket:
      • One 2.0 mm‑long screw securing the top of the bracket.
      • One 2.5 mm‑long screw securing the bottom of the bracket.
      • On models without cellular, remove the screws in this image instead.
      Ask FixBot
    2. iPad Pro 13" Lock Button Removal, Disconnect the camera: step 2, image 1 of 3 iPad Pro 13" Lock Button Removal, Disconnect the camera: step 2, image 2 of 3 iPad Pro 13" Lock Button Removal, Disconnect the camera: step 2, image 3 of 3
      • Place the flat end of a spudger between the camera ribbon cable and the top button ribbon cable, against the camera press connector.
      • While holding the top button ribbon cable down with the spudger, twist the spudger to disconnect the rear camera press connector.
      • Lift the camera ribbon cable up so it's nearly vertical to keep it out of the way.
      Ask FixBot
    3. iPad Pro 13" Lock Button Removal, Disconnect the lock button: step 3, image 1 of 2 iPad Pro 13" Lock Button Removal, Disconnect the lock button: step 3, image 2 of 2
      • Use the flat end of a spudger to disconnect the lock button press connector.
      Ask FixBot
    4. iPad Pro 13" Lock Button Removal, Remove the lock button and bracket: step 4, image 1 of 3 iPad Pro 13" Lock Button Removal, Remove the lock button and bracket: step 4, image 2 of 3 iPad Pro 13" Lock Button Removal, Remove the lock button and bracket: step 4, image 3 of 3
      • Slide an opening pick under the lock button press connector.
      • While pressing the opening pick up against the lock button ribbon cable, slide the pick under the cable to release the adhesive securing it to the iPad.
      • There are two pads under the ribbon cable. Be careful not to peel these up. If you do peel them up, place them back in their original positions.
      • Remove the lock button and bracket.
      • If you're just replacing this part and not the lock button cap, skip the next 8 steps.
      Ask FixBot
    5. iPad Pro 13" Lock Button Removal, Remove the lock button cap screws: step 5, image 1 of 2 iPad Pro 13" Lock Button Removal, Remove the lock button cap screws: step 5, image 2 of 2
      • Removing the screws in this step may cause the plunger, lock button, and retaining clip to fall out, so work carefully over a clean work surface.
      • Use a JIS 00 screwdriver to remove the two 1.6 mm‑long screws securing the lock button retaining clip.
      Ask FixBot
    6. iPad Pro 13" Lock Button Removal, Remove the plunger: step 6, image 1 of 2 iPad Pro 13" Lock Button Removal, Remove the plunger: step 6, image 2 of 2
      • Use tweezers or your fingers to remove the plunger from the lock button cap.
      • Note that this is small, non-magnetic, and round, so place it somewhere safe if you're not replacing it!
      Ask FixBot
    7. iPad Pro 13" Lock Button Removal, Remove the lock button cap: step 7, image 1 of 3 iPad Pro 13" Lock Button Removal, Remove the lock button cap: step 7, image 2 of 3 iPad Pro 13" Lock Button Removal, Remove the lock button cap: step 7, image 3 of 3
      • Use a pair of angled tweezers or a spudger to gently push the lock button cap and retaining clip out of the iPad frame.
      • Alternatively, you can tilt the iPad to let these pieces fall out.
      Ask FixBot
Finish Line
Author
with
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 122
