iPad Pro 12.9" Display Assembly Replacement
  1. iPad Pro 12.9" Display Assembly Replacement, iOpener Heating: step 1, image 1 of 2 iPad Pro 12.9" Display Assembly Replacement, iOpener Heating: step 1, image 2 of 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad Pro 12.9" Display Assembly Replacement: step 2, image 1 of 1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100ËšC (212ËšF).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad Pro 12.9" Display Assembly Replacement: step 3, image 1 of 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad Pro 12.9" Display Assembly Replacement, Alternate iOpener heating method: step 4, image 1 of 2 iPad Pro 12.9" Display Assembly Replacement, Alternate iOpener heating method: step 4, image 2 of 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad Pro 12.9" Display Assembly Replacement, Display Assembly: step 5, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement, Display Assembly: step 5, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement, Display Assembly: step 5, image 3 of 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad Pro 12.9" Display Assembly Replacement: step 6, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 6, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 6, image 3 of 3
    • Removing the display assembly involves using a halberd spudger or opening pick to separate the adhesive securing the display to the rear case.
    • Use the photos in this step to know the locations of the adhesive and where it is the thickest.
    • Refer to these images while following the guide to see where the adhesive is thickest and where to cut the deepest with your opening tool.
  7. iPad Pro 12.9" Display Assembly Replacement: step 7, image 1 of 1
    • Lay the hot iOpener over the left edge of the iPad to soften the adhesive holding it in place.
    • Alternatively, use a heat gun, hair dryer, or heat pad to heat the perimeter of your iPad.
    • Wait about two minutes for the adhesive to soften before proceeding to the next step.
  8. iPad Pro 12.9" Display Assembly Replacement: step 8, image 1 of 1
    • Attach a suction handle to the left edge of the iPad's display, equidistant from the top and bottom corners.
  9. iPad Pro 12.9" Display Assembly Replacement: step 9, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 9, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 9, image 3 of 3
    • While holding down the corners of the device, repeatedly pull up on the display then ease it back down to weaken the adhesive.
    • Once you've opened a small gap between the front panel and the rear case, insert the blade of a halberd spudger or an opening pick in the gap you've created.
    • Do not insert the pick more than 2 millimeters. Going any farther will permanently damage the display assembly. If using a halberd spudger, slice with the shortest part of the blade.
  10. iPad Pro 12.9" Display Assembly Replacement: step 10, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 10, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 10, image 3 of 3
    • Lay a hot iOpener along the bottom left corner of the iPad, spanning from the opening pick to the home button.
    • After letting the adhesive soften, insert a halberd spudger into the iPad next to the opening pick.
    • An opening pick can be used in place of the halberd spudger. Use caution if using an opening pick, as inserting the pick too far can damage the display assembly.
    • Cut the adhesive along the bottom left side of the iPad using the halberd spudger. This may require reheating the edge of the iPad.
    • Continue to slide the halberd spudger back and forth to ensure most of the adhesive is separated.
  11. iPad Pro 12.9" Display Assembly Replacement: step 11, image 1 of 2 iPad Pro 12.9" Display Assembly Replacement: step 11, image 2 of 2
    • Insert a pick in the bottom left corner of the iPad to ensure that the adhesive doesn't completely reset.
    • Remove the halberd spudger.
  12. iPad Pro 12.9" Display Assembly Replacement: step 12, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 12, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 12, image 3 of 3
    • Lay a hot iOpener along the upper left corner of the iPad, spanning from the opening pick to the front-facing camera.
    • After letting the adhesive soften, insert the blade of your halberd spudger into the iPad above the opening pick.
    • Cut the adhesive along the upper left side of the iPad towards the front-facing camera using the halberd spudger. This may require reheating the edge of the iPad.
  13. iPad Pro 12.9" Display Assembly Replacement: step 13, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 13, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 13, image 3 of 3
    • Insert a pick in the upper left corner of the iPad.
  14. iPad Pro 12.9" Display Assembly Replacement: step 14, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 14, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 14, image 3 of 3
    • Reheat your iOpener and lay it over the top edge of the device. Wait a couple minutes for the adhesive to soften.
    • Once the front panel is adequately heated, insert the blade of a halberd spudger next to the opening pick from the previous step.
    • Slide the blade along the top edge of the iPad, stopping before reaching the front-facing camera.
  15. iPad Pro 12.9" Display Assembly Replacement: step 15, image 1 of 2 iPad Pro 12.9" Display Assembly Replacement: step 15, image 2 of 2
    • Insert an opening pick just before the front-facing camera.
  16. iPad Pro 12.9" Display Assembly Replacement: step 16, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 16, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 16, image 3 of 3
    • If necessary, reheat your iOpener and lay it over the top edge of the device. Wait a couple minutes for the adhesive to soften before reinserting the blade of the halberd spudger.
    • Insert the blade of the halberd spudger just past the front-facing camera, on the opposite side of the opening pick.
    • Continue to slide the blade of the halberd spudger to the upper right corner of the iPad.
  17. iPad Pro 12.9" Display Assembly Replacement: step 17, image 1 of 2 iPad Pro 12.9" Display Assembly Replacement: step 17, image 2 of 2
    • Bring the halberd spudger around the corner of the iPad and insert an opening pick in the upper right corner to prevent the adhesive from resettling.
  18. iPad Pro 12.9" Display Assembly Replacement: step 18, image 1 of 2 iPad Pro 12.9" Display Assembly Replacement: step 18, image 2 of 2
    • Soften the adhesive by heating the right edge of the iPad using an iOpener.
    • Continue using the halberd spudger to cut away the adhesive holding the display assembly in place, stopping at the middle of the right edge.
  19. iPad Pro 12.9" Display Assembly Replacement: step 19, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 19, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 19, image 3 of 3
    • Remove the pick that was placed in the middle of the top edge of the iPad, next to the front-facing camera.
    • If you have extra opening picks or similar tools you do not need to remove this one.
    • Insert that pick in the middle of the right edge of the iPad.
  20. iPad Pro 12.9" Display Assembly Replacement: step 20, image 1 of 2 iPad Pro 12.9" Display Assembly Replacement: step 20, image 2 of 2
    • Insert the halberd spudger between the display and rear case, along the right edge of the device.
    • Slide the halberd spudger down the side of the iPad to separate the adhesive.
  21. iPad Pro 12.9" Display Assembly Replacement: step 21, image 1 of 2 iPad Pro 12.9" Display Assembly Replacement: step 21, image 2 of 2
    • Bring the blade of your opening tool around the lower right corner of the device.
    • Insert a pick in the lower right corner of the iPad where you slid the blade through.
  22. iPad Pro 12.9" Display Assembly Replacement: step 22, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 22, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 22, image 3 of 3
    • Use an iOpener to heat the bottom of the iPad.
    • Insert the blade of a halberd spudger to the left of the opening pick on the bottom right corner of the iPad.
    • Slide the halberd spudger along the lower edge of the iPad stopping short about 1 centimeter before reaching the home button.
  23. iPad Pro 12.9" Display Assembly Replacement: step 23, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 23, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 23, image 3 of 3
    • Remove the pick in the middle of the left side of the iPad.
    • Insert the pick to the right of home button.
  24. iPad Pro 12.9" Display Assembly Replacement: step 24, image 1 of 2 iPad Pro 12.9" Display Assembly Replacement: step 24, image 2 of 2
    • Pivot the halberd spudger so that you are slicing with the shortest portion of the blade.
    • Slide the halberd spudger to cut the adhesive below the home button.
  25. iPad Pro 12.9" Display Assembly Replacement: step 25, image 1 of 2 iPad Pro 12.9" Display Assembly Replacement: step 25, image 2 of 2
    • Reinsert the blade of the halberd spudger as deep as it will go.
    • Continue sliding the blade along the edge until you reach the first opening pick you inserted.
  26. iPad Pro 12.9" Display Assembly Replacement: step 26, image 1 of 2 iPad Pro 12.9" Display Assembly Replacement: step 26, image 2 of 2
    • Return to step 5 of this guide and ensure the thick portions of adhesive are adequately separated from the display assembly. If they are, continue with this step. Otherwise, slice the adhesive to break it up until the display assembly is freed.
    • The display cables in this iPad are shorter than some users may be comfortable with. Read the following warnings before proceeding:
    • Do not pivot the display about the lower edge. The display cables do not have enough slack to allow for this and will tear if you do not slide the display towards the front-facing camera as you lift.
    • The display cables will tear if you raise the display more than 80Âş.
    • Lift up the upper edge of the display and slide it towards the front-facing camera to access the iPads internal components.
  27. iPad Pro 12.9" Display Assembly Replacement: step 27, image 1 of 1
    • It's important to disconnect the battery before you proceed further. Detaching or connecting the display cables with the battery plugged in can cause a short that will destroy touchscreen functionality.
    • To disconnect the battery:
    • First, securely prop up the display so that it won't fall or strain the display cables while you work.
    • Then, remove the nine Phillips screws securing the logic board EMI shield:
    • Eight 1.2 mm screws
    • One 2.4 mm screw
  28. iPad Pro 12.9" Display Assembly Replacement: step 28, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 28, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 28, image 3 of 3
    • Lift the logic board EMI shield from the edge nearest the top of the iPad.
    • Peel the EMI shield up from the logic board.
    • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
    • Remove the logic board EMI shield.
  29. iPad Pro 12.9" Display Assembly Replacement: step 29, image 1 of 1
    • Remove the 1.8 mm Phillips screw securing the battery connector.
  30. iPad Pro 12.9" Display Assembly Replacement: step 30, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 30, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 30, image 3 of 3
    • Insert a Battery Blocker or other insulator underneath the logic board to separate it from the battery connector.
    • The battery blocker is an outdated way of isolating the battery, as you risk damaging the battery pins underneath the logic board. If you use this method, take extreme care to insert it gently and straight in the direction of the logic board. Don't significantly deform the the logic board as you do this. Don't twist or swing the pick side to side.
    • Leave it there to prevent the battery connector leads from making contact until you have completed your repairs.
    • The rest of the images in this guide show the logic board EMI shield reinstalled, which is incorrect. Follow the instructions, but keep the battery disconnected and do not reinstall the EMI shield until your repairs are complete.
  31. iPad Pro 12.9" Display Assembly Replacement: step 31, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 31, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 31, image 3 of 3
    • While supporting the display assembly, remove the following three Phillips screws over the display cable bracket.
    • 2.4 mm Phillips screw
    • 1.2 mm Phillips screw
    • Remove the display cable bracket.
  32. iPad Pro 12.9" Display Assembly Replacement: step 32, image 1 of 3 iPad Pro 12.9" Display Assembly Replacement: step 32, image 2 of 3 iPad Pro 12.9" Display Assembly Replacement: step 32, image 3 of 3
    • Use the flat end of a spudger to disconnect the two display data and digitizer cables from their respective sockets on the motherboard.
  33. iPad Pro 12.9" Display Assembly Replacement: step 33, image 1 of 1
Evan Noronha
223,466 Reputation
168 Guides authored
Past 24 Hours: 39
Past 7 Days: 205
Past 30 Days: 1,025
All Time: 150,670
