iPad Mini CDMA Bottom Left Antenna Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini CDMA Bottom Left Antenna Replacement, Bottom Left Antenna: step 1, image 1 of 1
    • Remove the following three screws securing the bottom left antenna to the rear case:
    • One 1.2 mm Phillips #00
    • One 1.1 mm Phillips #00
    • One 2.5 mm Phillips #00
  2. iPad Mini CDMA Bottom Left Antenna Replacement: step 2, image 1 of 2 iPad Mini CDMA Bottom Left Antenna Replacement: step 2, image 2 of 2
    • Use the flat end of a spudger to loosen the foam adhesive securing the Wi-Fi antenna to the left speaker.
  3. iPad Mini CDMA Bottom Left Antenna Replacement: step 3, image 1 of 2 iPad Mini CDMA Bottom Left Antenna Replacement: step 3, image 2 of 2
    • Use the flat end of a spudger to fold the left-hand wide piece of tape away from the left speaker.
  4. iPad Mini CDMA Bottom Left Antenna Replacement: step 4, image 1 of 1
    • The antenna cable is secured with two pieces of tape: the wide tape that continues onto the rear case, and its own small piece of tape that is covered by the wide tape.
    • In the next steps you'll be separating the wide tape from the antenna cable's tape with the tip of a spudger in the gap between the two pieces.
  5. iPad Mini CDMA Bottom Left Antenna Replacement: step 5, image 1 of 3 iPad Mini CDMA Bottom Left Antenna Replacement: step 5, image 2 of 3 iPad Mini CDMA Bottom Left Antenna Replacement: step 5, image 3 of 3
    • Pull the wide tape toward the top of the iPad, applying constant force to release it from the antenna cable between it and the speaker.
    • Slide the tip of a spudger through the gap between the wide tape and the antenna cable, to break the adhesive connecting the two.
    • Continue pulling the wide tape until it is no longer covering the antenna cable.
  6. iPad Mini CDMA Bottom Left Antenna Replacement: step 6, image 1 of 1
    • The right-hand wide piece of tape covers the antenna cable in the same way as the left.
  7. iPad Mini CDMA Bottom Left Antenna Replacement: step 7, image 1 of 3 iPad Mini CDMA Bottom Left Antenna Replacement: step 7, image 2 of 3 iPad Mini CDMA Bottom Left Antenna Replacement: step 7, image 3 of 3
    • Slide the tip of a spudger through the gap between the wide tape and the antenna cable, to release the adhesive connecting the two.
  8. iPad Mini CDMA Bottom Left Antenna Replacement: step 8, image 1 of 3 iPad Mini CDMA Bottom Left Antenna Replacement: step 8, image 2 of 3 iPad Mini CDMA Bottom Left Antenna Replacement: step 8, image 3 of 3
    • Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
    • Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
  9. iPad Mini CDMA Bottom Left Antenna Replacement: step 9, image 1 of 2 iPad Mini CDMA Bottom Left Antenna Replacement: step 9, image 2 of 2
    • Pull the antenna cable from the slot behind the Lightning connector.
  10. iPad Mini CDMA Bottom Left Antenna Replacement: step 10, image 1 of 2 iPad Mini CDMA Bottom Left Antenna Replacement: step 10, image 2 of 2
    • Use the tip of the spudger to pry the antenna cable tape up from behind the right speaker as well.
  11. iPad Mini CDMA Bottom Left Antenna Replacement: step 11, image 1 of 3 iPad Mini CDMA Bottom Left Antenna Replacement: step 11, image 2 of 3 iPad Mini CDMA Bottom Left Antenna Replacement: step 11, image 3 of 3
    • Use the tip of a spudger to remove the small piece of tape securing the antenna cable in the bottom right corner of the iPad.
  12. iPad Mini CDMA Bottom Left Antenna Replacement: step 12, image 1 of 2 iPad Mini CDMA Bottom Left Antenna Replacement: step 12, image 2 of 2
    • Pull the antenna cable away from its recess in the rear case.
  13. iPad Mini CDMA Bottom Left Antenna Replacement: step 13, image 1 of 3 iPad Mini CDMA Bottom Left Antenna Replacement: step 13, image 2 of 3 iPad Mini CDMA Bottom Left Antenna Replacement: step 13, image 3 of 3
    • Use the tip of a spudger to pry the small metal retaining clip off the antenna cable.
    • De-route the antenna cable from the clip.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 106
