Installing iPad Mini CDMA Small Metal Bracket
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing iPad Mini CDMA Small Metal Bracket, Small Metal Bracket: step 1, image 1 of 3 Installing iPad Mini CDMA Small Metal Bracket, Small Metal Bracket: step 1, image 2 of 3 Installing iPad Mini CDMA Small Metal Bracket, Small Metal Bracket: step 1, image 3 of 3
    • Use the tip of a spudger to start peeling up the right side of the black tape covering the small metal bracket.
    • Use tweezers to peel the tape up the rest of the way, and remove it from the bracket.
  2. Installing iPad Mini CDMA Small Metal Bracket: step 2, image 1 of 2 Installing iPad Mini CDMA Small Metal Bracket: step 2, image 2 of 2
    • Use a plastic opening tool to push the bracket slightly to the left.
  3. Installing iPad Mini CDMA Small Metal Bracket: step 3, image 1 of 2 Installing iPad Mini CDMA Small Metal Bracket: step 3, image 2 of 2
    • Use a spudger tip to lift up the lower side of the bracket.
  4. Installing iPad Mini CDMA Small Metal Bracket: step 4, image 1 of 2 Installing iPad Mini CDMA Small Metal Bracket: step 4, image 2 of 2
    • Remove the bracket with tweezers.
    • During reassembly, hook the top edge of the plate in place first, then lower the bottom into its slots.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 122
