Installing iPad Mini CDMA Battery Connector
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing iPad Mini CDMA Battery Connector, Battery Connector: step 1, image 1 of 1
    • Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
  2. Installing iPad Mini CDMA Battery Connector: step 2, image 1 of 1
    • Use a pair of tweezers to grasp and remove the connector shield from the iPad.
  3. Installing iPad Mini CDMA Battery Connector: step 3, image 1 of 2 Installing iPad Mini CDMA Battery Connector: step 3, image 2 of 2
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
Andrew Optimus Goldheart
503,578 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 516
