iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement, Headphone Jack Cable: step 1, image 1 of 2 iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement, Headphone Jack Cable: step 1, image 2 of 2
    • Use a plastic opening tool to gently fold the front-facing camera cable upwards (roughly at a 90-degree angle), exposing the bottom side of it.
  2. iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 2, image 1 of 2 iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 2, image 2 of 2
    • Use a set of tweezers to peel up the small piece of tape covering the headphone jack cable connector.
  3. iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 3, image 1 of 2 iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 3, image 2 of 2
    • Use the tip of a spudger to gently lift the tab on the microphone ribbon cable's ZIF connector.
  4. iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 4, image 1 of 2 iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 4, image 2 of 2
    • Slide the tip of a tweezer under the microphone cable to separate it from the adhesive holding it to the headphone jack cable.
  5. iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 5, image 1 of 3 iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 5, image 2 of 3 iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 5, image 3 of 3
    • Use tweezers to pull the microphone cable straight out from its ZIF socket.
    • Gently bend the microphone cable up and out of the way of the headphone jack cable.
  6. iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 6, image 1 of 1
    • Remove any tape covering the headphone jack cable connector.
  7. iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 7, image 1 of 3 iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 7, image 2 of 3 iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 7, image 3 of 3
    • Use a plastic opening tool to fold the headphone jack cable clips outward, away from the cable, freeing the cable connector.
  8. iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 8, image 1 of 2 iPad Mini 3 Wi-Fi Headphone Jack Cable Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to pry the headphone jack cable's connector up from its socket on the logic board.
Sam Goldheart
466,364 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,494 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 76
