iPad Mini 3 Wi-Fi Front Panel Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPad Mini 3 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 2 of 2
      • Use the tip of a spudger to lift the digitizer cable connector straight up off of its socket.
      Ask FixBot
    2. iPad Mini 3 Wi-Fi Front Panel Assembly Replacement: step 2, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Assembly Replacement: step 2, image 2 of 2
      • Slide the flat end of a spudger under the battery side of the digitizer board to begin separating it from the rear case.
      Ask FixBot
    3. iPad Mini 3 Wi-Fi Front Panel Assembly Replacement: step 3, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Assembly Replacement: step 3, image 2 of 2
      • Lift the digitizer board up to free the last of the adhesive.
      Ask FixBot
    4. iPad Mini 3 Wi-Fi Front Panel Assembly Replacement: step 4, image 1 of 1
      • Lift and remove the front panel assembly from the iPad.
      Ask FixBot
Evan Noronha
229,803 Reputation
166 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 22
All Time: 627
