iPad Mini 3 Left Antenna Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini 3 Left Antenna Cable Replacement, Left Antenna Cable: step 1, image 1 of 3 iPad Mini 3 Left Antenna Cable Replacement, Left Antenna Cable: step 1, image 2 of 3 iPad Mini 3 Left Antenna Cable Replacement, Left Antenna Cable: step 1, image 3 of 3
    • Pull the wide tape toward the battery, applying constant force to peel it from the antenna cable lodged between it and the speaker.
    • Insert a plastic opening tool into the gap between the wide tape and the antenna cable, to break the adhesive connecting the two.
    • Slide the plastic opening tool along the length of the antenna cable to completely separate it from the piece of tape.
  2. iPad Mini 3 Left Antenna Cable Replacement: step 2, image 1 of 3 iPad Mini 3 Left Antenna Cable Replacement: step 2, image 2 of 3 iPad Mini 3 Left Antenna Cable Replacement: step 2, image 3 of 3
    • Lift the antenna cable tape up from behind the right speaker.
  3. iPad Mini 3 Left Antenna Cable Replacement: step 3, image 1 of 2 iPad Mini 3 Left Antenna Cable Replacement: step 3, image 2 of 2
    • Pull the antenna cable out from under the corner of the right speaker.
Sam Goldheart
466,950 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
140 Members
17,681 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 79
