iPad Mini 3 Left Antenna Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini 3 Left Antenna Replacement, Left Antenna Cable: step 1, image 1 of 1
    • Remove the following Phillips #00 screws from the left antenna:
    • One 2.6 mm screw
    • Two 1.5 mm screws
  2. iPad Mini 3 Left Antenna Replacement: step 2, image 1 of 2 iPad Mini 3 Left Antenna Replacement: step 2, image 2 of 2
    • Use the flat end of a spudger to loosen the foam adhesive securing the Wi-Fi antenna to the left speaker.
  3. iPad Mini 3 Left Antenna Replacement: step 3, image 1 of 2 iPad Mini 3 Left Antenna Replacement: step 3, image 2 of 2
    • Use the flat end of a spudger to fold the wide left-hand piece of tape away from the left speaker.
  4. iPad Mini 3 Left Antenna Replacement: step 4, image 1 of 3 iPad Mini 3 Left Antenna Replacement: step 4, image 2 of 3 iPad Mini 3 Left Antenna Replacement: step 4, image 3 of 3
    • Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
    • Gently pull the antenna cable out of the way as you work along the piece of tape to free it and keep it from resealing.
  5. iPad Mini 3 Left Antenna Replacement: step 5, image 1 of 2 iPad Mini 3 Left Antenna Replacement: step 5, image 2 of 2
    • Pull the antenna cable from the clip behind the Lightning connector.
Sam Goldheart
466,904 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
138 Members
17,678 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 100
