Introduction
Use this guide to fix your iPad Mini 2 screen. This guide will show you how to replace the front panel, including digitizer, home button, and display glass on your iPad Mini 2 Wi-Fi.
Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
Slide the spudger under the battery side of the digitizer board to begin separating it from the rear case.
Lift the digitizer board up to free the last of the adhesive.
