iPad Mini 2 Wi-Fi Front Panel Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: step 1, image 1 of 2 iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: step 1, image 2 of 2
    • Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
    • Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
  2. iPad Mini 2 Wi-Fi Front Panel Replacement: step 2, image 1 of 3 iPad Mini 2 Wi-Fi Front Panel Replacement: step 2, image 2 of 3 iPad Mini 2 Wi-Fi Front Panel Replacement: step 2, image 3 of 3
    • Slide the spudger under the battery side of the digitizer board to begin separating it from the rear case.
    • Lift the digitizer board up to free the last of the adhesive.
  3. iPad Mini 2 Wi-Fi Front Panel Replacement: step 3, image 1 of 1
    • Lift and remove the front panel from the iPad.
Sam Goldheart
465,970 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,299 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 6,538
