iPad 4 Wi-Fi Power & Volume Button Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPad 4 Wi-Fi Power & Volume Button Assembly Replacement, Power & Volume Button Assembly: step 1, image 1 of 1
      • Remove the following screws securing the power & volume button cable to the aluminum frame:
      • Two 5.5 mm Phillips #0
      • One 2.6 mm Phillips #0
      • Two 2.6 mm Phillips #0
      • The two screws located on top are angled into the aluminum frame. Be sure to always hold the screwdriver in line with the screw.
      Ask FixBot
    2. iPad 4 Wi-Fi Power & Volume Button Assembly Replacement: step 2, image 1 of 1
      • Remove the piece of plastic covering the volume buttons.
      Ask FixBot
    3. iPad 4 Wi-Fi Power & Volume Button Assembly Replacement: step 3, image 1 of 1
      • Remove the single 2.6 mm Phillips #00 screw holding the volume button frame to the aluminum frame.
      • This screw is angled into the aluminum frame. Be sure to always hold the screwdriver in line with the screw.
      Ask FixBot
    4. iPad 4 Wi-Fi Power & Volume Button Assembly Replacement: step 4, image 1 of 1
      • Wedge the edge of a plastic opening tool underneath the sleep/wake sensor, being careful to not damage the fragile cable.
      • Move the plastic opening tool around the sensor, releasing the adhesive.
      Ask FixBot
    5. iPad 4 Wi-Fi Power & Volume Button Assembly Replacement: step 5, image 1 of 2 iPad 4 Wi-Fi Power & Volume Button Assembly Replacement: step 5, image 2 of 2
      • Slide the tip of a spudger underneath the power & volume cables, releasing the adhesive.
      Ask FixBot
    6. iPad 4 Wi-Fi Power & Volume Button Assembly Replacement: step 6, image 1 of 3 iPad 4 Wi-Fi Power & Volume Button Assembly Replacement: step 6, image 2 of 3 iPad 4 Wi-Fi Power & Volume Button Assembly Replacement: step 6, image 3 of 3
      • Using the tip of the spudger rather that the wide edge, release the adhesive underneath the volume button branch of the ribbon cable.
      • Continue sliding the tip of the spudger toward the top of the iPad, releasing the adhesive.
      • With the tip of the spudger still underneath the ribbon cable, gently lift the power button out of its socket in the aluminum frame.
      Ask FixBot
    7. iPad 4 Wi-Fi Power & Volume Button Assembly Replacement: step 7, image 1 of 1
      • Lift and remove the power & volume button cable out of the iPad.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 418
