iPad 4 CDMA Home Button Control Board Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPad 4 CDMA Home Button Control Board Replacement, Home Button Control Board: step 1, image 1 of 2 iPad 4 CDMA Home Button Control Board Replacement, Home Button Control Board: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • The two small notched trapezoidal strips will be used to attach the home button bracket to the front panel.
      • Carefully peel off the first trapezoidal adhesive strip with a pair of tweezers.
      • Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
      • Make sure to line up the profile of the strip with the edge of the mounting bracket.
      • Repeat the procedure for the second trapezoidal adhesive strip.
      Ask FixBot
    2. iPad 4 CDMA Home Button Control Board Replacement: step 2, image 1 of 1
      • Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
      • Lift and peel the clear backing up off the adhesive strip, revealing the black adhesive strip.
      • Repeat the procedure for the secondary adhesive strip.
      Ask FixBot
    3. iPad 4 CDMA Home Button Control Board Replacement: step 3, image 1 of 2 iPad 4 CDMA Home Button Control Board Replacement: step 3, image 2 of 2
      • Gently place the home button mounting bracket on top of the home button.
      • Make sure the home button mounting bracket is lined up with the bottom of the digitizer.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 507
